Is it possible to lug a truck at peek RPM?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Richter, Aug 9, 2014.
  1. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    So I have a cummins ISX (07 emissions, has regen, no def) in a Kenworth T660 with a dirrect 10 speed trans.
    When going up a moderate hill in 10th, it will maintain speed and rpm (1400-1500). It kinda feels and sounds like its lightly lugging, but at that rpm it shouldn't be. Am I overworking the motor to maintain speed and RPM? Should I slow down and downshift a gear or is it fine to work the motor this hard. Its not a real bad lug, just a little more vibration.
    I've never notices this on my other truck which is a detroit, although that truck does not aintain speed in top gear as well.
    bobbyhill Thanks this.
  3. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,424
    Dec 10, 2011
    Weed, CA
    Just thinking if the engine will maintain speed, what's the problem? It's working harder on uphill pulls, which means more fuel and a deeper exhaust sound - maybe that's what you're hearing?
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Normal, you are just hearing the engine working harder. Lugging isn't until it is down to 1000 rpm.
    Richter Thanks this.
  5. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    This is where a pyrometer and boost gauge come in handy. While the spec sheets show peak RPM at 1000, it is usually not advisable, even by the OEM, to run full power on a hard pull for more than a few seconds at that low of a RPM, or even 1100. Exhaust temps at those low RPM's could easily climb to too high of levels than are prudent. At that point, the engine is fighting with itself and an excessive amount of heat is being generated. There is a balance, and each engine is a little different. If I still had a lot of hill to pull, I would keep RPM's above 1300. I have let ISX's go on down lower, but I was about ready to crest the hill and I knew that it would not be running that low for more than a few seconds. To the OP, there is really no way any ISX should be even close to "lugging" at 1400-1500 rpm.
  6. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I norm keep at least 1300 rpm going up hill but prefer 1400ish. I dont have pyro, but do have boost. Im quite surprised by how much power this truck has in top gear. (cummins isx only 400HP) I can take most hills at 1400ish without downshifting. Im really liking this direct top gear and 2.64 rear.
    I forgot, do you have 2,64 or 2.79...you run in direct right?
  7. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    If your keeping it in the "sweet spot" then I wouldn't call it lugging....
  8. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    First we need to define "lug" - "To carry or drag with great effort".
    There is no specific rpm which defines lug. It is when the engine is working at an inefficient rpm to capably do it's work when a gear change to a higher rpm would be more efficient.
    Unless you have a pyrometer and boost gauge you are just guessing by sound and feel.
    Hardlyevr Thanks this.
  9. j_martell
    284
    184
    Jun 12, 2014
    Yep there is.....my Mack says do not run under 1200rpm....the old Mack is not under 1400.....both values are the start of the max torque curve (straight line) of the individual motors.....
    Keep it in the operating range (or torque curve if you have access to a power graph) and you should be good....
  10. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    I have lugged an ISX15 back all the way to 900 rpm multiple times without any problems. I don't advise going down to 900 but you would want to shift to a lower gear by 1000 rpm. Lugging the ISX down to 1000 rpm (2010 and newer) won't hurt it at all. I haven't ruined an engine by doing that yet and I will run it down to that RPM for as long as I can because of the gear down protection and load based speed control that they have on the trucks now. I believe that the 2013 ISX has full torque all the way down to 1000 rpm.
  11. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    this a 2010 truck with a 07 emission motor.
