is it possible for the trailer axles to get out of alignment?
Discussion in 'Questions From New Drivers' started by DeepSouthRollin, Apr 24, 2018.
  1. DeepSouthRollin
    DeepSouthRollin Light Load Member
    82
    55
    Apr 14, 2018
    louisiana
    Seems like one trailer at school definitely drifts to the right when backing compared to the other trailers...
    Thanks
  3. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    Yes but it isn't that obvious when backing because of the low speed and short distance. It would be obvious at highway speed. If the axle was out of alignment enough to effect it backing up,it would be pretty obvious by looking at it that it is messed up.
  4. DeepSouthRollin
    82
    55
    Apr 14, 2018
    louisiana
    by obvious you mean that the hubs and tires would get hot after driving?
    OR, just tracking to one side, like you would see more trailer in the mirrors on one side VS the other side?
    we are completely green, so, what is obvious to a seasoned driver may not be so for the rookie...
    Please clarify
    Brickwall Thanks this.
  5. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    Yes they get knocked out from bouncing off of curbs (and other things) all the time, you can see it in mirror by comparing the distance between the fog line and the tires on trailer to the distance between the truck tires and the fog line when driving straight.
  6. DeepSouthRollin
    82
    55
    Apr 14, 2018
    louisiana
    cool, what is a fog line, is it like a skyhook, or a left handed hammer?
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I found some trailers off track if the pins are not fully engaged into the holes on the trailer that the tandems slide under when you want them transfer weight.
  8. brysol01
    brysol01 Medium Load Member
    312
    445
    Nov 2, 2009
  9. driverdriver
    driverdriver Road Train Member
    4,254
    5,282
    May 30, 2011
    Lol No , but you can find one in the lumber section next to the board stretchers.
    Seriously though , the fogline is the solid white line on the shoulder.
    Brettj3876, dan31186 and Aces-N-Eights Thank this.
  10. DeepSouthRollin
    82
    55
    Apr 14, 2018
    louisiana
    thanks, never heard that one before.
    We just call it the white line, or , where the reflectors are supposed to be
    NEVER STOP LEARNING
    x1Heavy, driverdriver and uncleal13 Thank this.
  11. Yup68
    Yup68 Bobtail Member
    6
    9
    Mar 29, 2018
