Is it OK to use Bar's leak to to seal the head gasket
Discussion in 'Freightliner Forum' started by tin714, Apr 21, 2014.
  1. tin714
    tin714 Bobtail Member
    16
    Apr 21, 2014
    Leaking coolant from the engine. Is it ok to use Bar's leak to put in the coolant reservoir. To seal the gasket. Any suggests thank you...
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Bar's Leak is only a temporary fix to a minor problem like a hairline crack in the head gasket. It also tends to clog radiators pores and coat sensors. I would never use it unless you absolutely needed to buy a week or two to raise money. Then you risk putting yourself in the position of a tow and set yourself back farther. It has to be fixed regardless, fix it now if you can.
    If it's leaking from the water pump you can forget it. You are not far from total failure like less than 100 miles.
    Are you company or OO? Where exactly is it leaking?
    chalupa Thanks this.
  4. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Mans right...... it will also clog every other small opening. Where the water is coming from is important however the key is nothing tossed in the radiator is a fix for a mechanical problem.
    Good luck
  5. fencitup
    fencitup Light Load Member
    225
    113
    Jan 12, 2014
    Bronx, NY
    These guys are correct. It seals everything but what needs to sealed. And, because it does such a great job of solving the problem for A WEEK, it's hard to resist using it 'just one more time'. All the while it's damaging other things as was stated.
  6. tin714
    16
    Apr 21, 2014
    Oo is leaking from the right side of the engine . From the line that join the engine ....is a minor dripping
  7. tin714
    16
    Apr 21, 2014
    Thank you guys!
  8. CondoCruiser
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    If it's a compression fitting it might just need a hair tightened to stop leaking. If it's a hose it either needs tightened or it might be cracked where the clamp digs in. It would need replaced but if you have the length you could get by with cutting the bad out. Usually a hose is degrading by that point.
  9. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    He plainly states it's the head gasket, not a water pump, not a fitting, not a hose. The head gasket. Op, if it's just a drop run her home, just carry a couple gallons of water with you. You can change a head gasket for 300 max. Ships gonna charge you over two grand. Might be time to break out the wrenches and get your hands dirty.
    EverLuc Thanks this.
  10. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    Only way I would use it is if I was putting it up for sale and I didnt have a conscience.
  11. bad-luck
    bad-luck Road Train Member
    3,246
    5,944
    Nov 16, 2013
    Baltimore, Maryland
    No no no. It will gunk up everything and will NOT work for a head gasket because the pressures are too high.. Coolant pressures generally only run between 7-13psi. You need to get it fixed
