Is it my responsibility to scale the truck and axle out?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by jumbo11, Nov 30, 2021.
  1. jumbo11
    jumbo11 Bobtail Member
    18
    6
    Jun 8, 2021
    8 axle tanker, 4 lift axles 4 regulators. long history of not getting it to axle scale. my question... is it my responsibility to get it to scale..? tractor and tanker are not mine i am a hourly employee. this is how i think it should go... If the company wants me to haul 50 ton all day every day then put 50 ton in it get the axles to scale and then and only then give it to me, and as a driver i maintain settings for that weight. or better yet set it up for 51 ton as a buffer and pull 50 without issue.
  3. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    You are the operator and driver. You figure it out. Sure they could give you some guidance but it's not that hard
  4. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Yes, you are responsible for making sure your load is legal. That's why you are a professional and paid accordingly.
  5. jumbo11
    18
    6
    Jun 8, 2021
    so guidance would be.. Before this tractor/tanker is put on the road, it gets loaded,scaled, all regulated axles are checked for correct pressure and then checked for proper weight on axles for whatever tonnage is to be loaded.
  6. jumbo11
    18
    6
    Jun 8, 2021
    where can i take the truck/tanker to weigh my axles individually..? the only one i have found has state troopers working there.
  7. kemosabi49
    10,438
    44,393
    Jan 13, 2013
    SW Arkansas
    Cat Scales at many truck stops.
    okiedokie, Cattleman84 and Pamela1990 Thank this.
  8. jumbo11
    18
    6
    Jun 8, 2021
    Scales to isolate 1 or 2 axles at a time..? I have looked for this and asked other drivers and have never been told this was a reality. full scale for gross weight , YES scales for individual axle weight NO. Please proove me wrong..!
  9. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    A cat scale has 3 different platforms so you pull on the scale and it will tell you steer axle weight, drive axle weight and trailer axles weights separately. You can also weight multi axle setups by moving forward or back to put different axles on the different platforms.
    You can also do this on a normal scale as well. Pull steer axle on and write down weight, pull next axle on and write down weight. Keep doing this until you've weighed the while thing, then with some simple math you can figure out axle weights.
    kylefitzy, LoboSolo, tscottme and 7 others Thank this.
  10. Dennixx
    Dennixx Road Train Member
    4,428
    13,954
    Feb 13, 2010
    twin cities
    We don't have sliding 5th or trlr axle adjustment.
    We load on a rear axle scale to 34 each trip.
    We are only responsible to be at 80 or under when we leave and axle weight is not our responsibility.
    Ultimately it is the operator's problem.
  11. Dennixx
    4,428
    13,954
    Feb 13, 2010
    twin cities
    There would be some math involved..lol
    Crude Truckin' and Cattleman84 Thank this.
