Is it legal to use a ball valve as a dump valve?
Discussion in 'Ask An Owner Operator' started by Dino soar, Jan 17, 2023.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I'm doing some work to reconfigure my trailer dump valve.
    Does anyone know if it is legal to use a ball valve as a dump valve? I know that for Airlines they want everything to say dot but I have not seen anything that says DOT approved ball valve.
    I may just run a line from the cab to the trailer and configure the dump valve that way without any outside shut off valve.
    Currently I have a quick connect Airline like you use in the garage for my air gauges for my trailer. I'm thinking they could give me a hard time about that?
    Any idea what would be better to use for that connection? I suppose I could use a glad hand but it's only a quarter inch line.
  3. 062
    062 Road Train Member
    6,143
    33,179
    Oct 20, 2013
    Trailers with the tire inflation use a valve to close the system if needed. I haven’t payed any attention to the valve, but I doubt it has dot markings.
  4. Judge
    84,584
    I’ve got 4 ball valves that operate the shakers on my hopper bottom, never been questioned.
  5. Long FLD
    Long FLD Road Train Member
    11,378
    45,908
    Mar 4, 2015
    My hopper had ball valves for the vibrators. The trailers where I’m leased now have a ball valve that will close off the tire inflation system.
  6. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    My new trucks have ball valves on them for optional air at back of cab. Not stamped DOT
  7. abyliks
    abyliks Road Train Member
    3,747
    8,695
    May 2, 2010
    ludlow MA
    I’ve got t valves on my air tank with the fittings to connect to shop air on it, I’ve honestly never even given it a second thought about them having to be dot approved
  8. SmallPackage
    5,278
    16,471
    Dec 20, 2019
    Marion Texas
    Before all the fancy suspension dump valve switches became a thing on dashes many a truck used the old timers trick of a ball valve on the leveling valves on suspension to dump the air. Otherwise the old air rides had no way of deflating other then loosening an air line. Never been a problem with dot in 40 years. My ‘67 has had one forever.
  9. Ridgeline
    22,112
    113,286
    Yes.
    Just buy quality valves.
    Rideandrepair, Dino soar and Siinman Thank this.
  10. MacLean
    MacLean Road Train Member
    1,270
    3,722
    Sep 12, 2017
    Hauling fluid and they let them go there so I’d think you can use them anywhere but yes, don’t buy junk. Not that I’d think you’d get wrote up for it but you’d pay the price of a good valve 100 times over when a cheap POS fails.
  11. Rideandrepair
    17,214
    55,886
    Aug 8, 2015
    Considering they’re usually rated for about 600 psi. I can’t imagine anyone questioning a ball valve, I always hear about DOT approved fittings. I’ve got a lot of fittings, that aren’t labeled DOT approved. Some claim plastic isn’t t allowed. There’s all kind of plastic ones, especially in the dash. I wouldn’t worry about any of it. I have a 1/4” ball valve on my SS bottom radiator pipe. Makes working on the road easier. Avoids a big mess. The fitting on the air tank, put a rubber cover over it. That’ll keep it clean too.
    Vampire, SmallPackage, Siinman and 2 others Thank this.
