Is it better to push the clutch in when starting the truck?
Discussion in 'Experienced Truckers' Advice' started by Burnt Clutch, Jan 20, 2024.
  1. Burnt Clutch
    Burnt Clutch Bobtail Member
    6
    4
    May 6, 2021
    Hey I was just wondering if anyone has a tip on whether you should push the clutch in when starting the truck. Specifically because I've heard it's supposed to be easier on the starter or easier on the engine or something. To me if its in neutral anyways it shouldn't make a difference. Besides that would require me to hop in front in a cold truck and have to put my slippers on instead of just reaching for the key.
    Rideandrepair and OLDSKOOLERnWV Thank this.
  3. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    Even in neutral. You're still spinning the trans.
    With the clutch in. You're only spinning the crank.
    Think cold oil engine and trans. Things are harder to crank when everything is cold.
  4. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Many newer trucks won’t start unless clutch is pushed in .
  5. slow pok
    slow pok Light Load Member
    144
    211
    Oct 27, 2013
    lizela ga
  6. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    sure it does make a difference. even in neutral you are still spinning a lot of gears in the transmission. But that being said I'd bet the difference is small and really isn't going to affect anything
  7. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    I knew this day would come,,:(, as mentioned, most vehicles won't start unless the clutch is depressed. In the warm, it doesn't make much difference, but in the cold, where you only have a limited amount of battery, turning over a cold trans might kill the deal. When cranking cold, and then push the clutch in, you'll notice the starter spins faster. That trans oil is like STP( I realize that dates me), and it's just a good practice for safety.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    You best better get in the habit of pushing the clutch in when you start anything with a clutch Simply for a safety reason some of the older trucks have no neutral safety switch’s they could start while in gear
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I definitely did push it in during cold weather.
    When it is extremely cold, several seconds after a successful start, I casually let the clutch out and the engine rpm would drop a noticeable amount. There can be a lot of drag there that can make a difference determining whether it turns over fast enough in extreme cold.
  10. Jamie01
    Jamie01 Light Load Member
    251
    519
    Dec 13, 2020
    prostartom, Opus, Hatt91 and 12 others Thank this.
  11. AModelCat
    154,242
    If you don't push the clutch and you have the extra drag created by the transmission.
    On the other hand, what happens when you push in the clutch? You're pulling on the release bearing. This also pulls the crankshaft back, which loads up the crankshaft thrust bearing.
    Is one more harmful than the other? Who knows?
