Is CAT 3406C any good?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by korky, Aug 25, 2013.
  1. korky
    korky Light Load Member
    97
    56
    Aug 14, 2013
    AZ
    I am looking to buy a 1998 Pete 378 with a 3406C CAT & 13spd. The truck has 530k and it had an inframe about 80k ago. I had a 3406B many years ago and from I remember it was an ok engine. Does anyone know if this is a good, reliable engine? I will be doing some mountain driving but more local and flatland than anything. Any info is greatly appreciated. thank you.
  3. fireba11
    fireba11 Heavy Load Member
    864
    541
    Jul 30, 2007
    Tracy City, TN
    I owned a truck with a 3406c engine in it and it was great. It was the first time I had a truck with cruise control and I loved it. A 3406c is basically the same as a B model except it has electronic accelerator and fuel measuring. The engine is really simple to work on.
    What I question is...what is a 3406c doing in a 1998 Pete? The 3406E was the Cat engine for that year. I would check and see if the truck is a glider kit! Also, why would it need a overhaul at 450k? Those engines run 1 mill miles easily! Something is fishy here!
  4. korky
    97
    56
    Aug 14, 2013
    AZ
    Sorry, the truck is a 1988 and its a daycab running local dumps. Thx for the info.
  5. NadeauTrucking
    NadeauTrucking Light Load Member
    85
    45
    Jul 24, 2011
    Bristol, CT
    The C engine is all mechanical unless it is a PEEC motor(PEEC=JUNK). i had a 97 ford ltl9000 with the C engine and it was ALL mechanical. Still 425hp, but they dont rev like the B engine because of newer emissions requirements.
  6. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    actually, if the build date was late 97, it could have still been an ALL mechanical C model. As far as the E model goes, you could one of those in a truck in as early as late 94. from 94 to 97 it could have been an E, C, or a B really.
  7. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    The old 3406 cat engines were good motors imo. Like the old Cummins Big cam, any competent diesel mechanic with a few marbles rolling around in his head could repair them. :)
    fireba11 and wore out Thank this.
  8. wore out
    wore out Numbered Classic
    15,319
    184,946
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I wouldn't worry about any engine that is stamped 3406. Its true what was posted earlier it could be a mechanical C, PEEK, or E. For the record PEEK does not equal junk there are several of us that were new to the game when them were new, we figured out if want to excel in this field learn the technology so you can properly diagnose and repair what everyone is so scared of without swapping it over to mechanical. Made many a truck owners and their drivers happy with the 4CK 460hp PEEK.
  9. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Finding those few people that know how to work on a PEEC is the problem. We had one in a Pete and it had a lot of power. Then it started having issues and we spent alot of money getting it repaired. Back in 04 when we had it and called local Blanchards they would just say "Oh boy" when you told them it was a PEEC. I think we probably had 3-4K in the fuel system issues in about 2.5 years. IF you can find someone that knows what they are doing or can swap it to mechanical then you have a great motor.
  10. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    They remind me of the sdp c15, a drastic change in electronic controls compared to what we were use to. The first people to see and work on them were probably scared to do so.but with proper understanding of how things work and not just throwing parts at them, they run well
  11. fireba11
    864
    541
    Jul 30, 2007
    Tracy City, TN
    Mine had the peek engine and I ordered a repair manual from CAT and was able to do most work myself. They were basically the same as a B model, except it had a electric controlled fuel pump. Engine ran great and I had very few problems with it.
