I have always seen people say buying a new truck is the best way to go. But is buying a used truck with a rebuilt engine good as well that after the overhaul has around 200,000 miles?
Is buying a used but rebuilt semi truck a good deal?
Discussion in 'Questions From New Drivers' started by Regional, Apr 21, 2020.
someone just pressure washing the engine and painting it, is not a rebuildalds and Deere hunter Thank this. -
Frankly I don’t know why anyone would want to start off with a new truck, 2000 and down with an n14 or even a Detroit that you can pay cash for, which will actually run
jsnell and MTN Boomer Thank this. -
You're looking at dump trucks, right?
200,000 miles is A LOT of use on a dump truck. Bet there's close to 8,000 hours on the rebuild.Brettj3876 and Cat sdp Thank this. -
Yeah dirt trucks get a lot of off road abuse with dust etc. A truck with 200k on a rebuild means it probably had close to a million when they did the rebuild. You need to know just what was done on the rebuild exactly. There's a difference between a new crank shaft and "turning" the old one as an example.
lovesthedrive Thanks this. -
Do a internet search onn the vin#. If the company had it rebuilt at a regular shop, the history can be viewed in the search.
Looking at engine hours on a local or off road truck is a much better way to determine usage.
Our shop determines maintenance intervals and fuel consumed on hours instead of miles.
It wouldn't work for everybody but it's better for us. The off road trucks might work a fourteen hour day and travel less than two hundred miles.AModelCat Thanks this. -
Pull the ECM data.
Used trucks that can work in California are a unicorn.......
Good luck finding one.
