Once a "log" day or at the beginning of every 11 hour shift?
This morning I drove an hour to a shipper to have a full day when my load started at 21:30.
I did a full pretrip inspection in the morning. Is anotherr required before I roll at 21:30?
If course I did a walk around. But do I have to log it and chew up another 15 minutes if my week?
Mikeeee
is a pretrip inspection required ...
Discussion in 'Experienced Truckers' Advice' started by Pmracing, Jan 15, 2012.
Page 1 of 10
49 CFR 392-8 Pre trip required. and 49 CFR 396-11 requires a Written Post Trip Inspection sheet to be filled out.
Pmracing, CondoCruiser, thehornet and 2 others Thank this. -
So im not fully understanding your post but here;s some info. Lets say I do my pretrip and work my 14 (did a post trip) I then take 10 off so yeah my next shift (no matter what day its on) I gotta do another pre-trip. You only have to mark 15 minutes for a pre-trip and you dont have to mark 15 for a post trip. Lets say in a 24 hr period (1 log page) I did a pretrip, drove 4 hrs, did a post trip and then took 10 off. When I come back on shift I still have to do a pre-trip and mark the 15 even though its still on the same day. Does this help or make sense?
chopper103in, Wiseguywireless and Pmracing Thank this. -
If you do not log it, how do you prove anything? Because if you do the paperwork for the post trip (as an example), and fill out the log sheet for the post trip, and you get stopped at a DOT check, and he looks through your logbook, he is not going to see where you actually did one.
Your post-trip paperwork has to match your log book. At least, this is the way I have been doing things, these past 20 years or so.thehornet, Onetruckpony and Zangief Thank this. -
I take it you're running paper logs.
If so, at the start, after the location lof your pre-trip. At the end of the day, after the location, make a note, next to it, PTI, That covers your post trip.
You're also required to do a cargo check wither 3 hours or 150 miles after starting out, whichever comes first. You can log that on your rest/lunch/head call stop, by noting ERI (en route insp.)
Those notations satisfy even the most anal retentive diesel cop. -
To clarify, it was the second start of a day all within 13 hours.
I started my day with a pretrip, drive an hour, then took a10 hour break again.
I logged both but was wondering if I had to.
Thanks,
Mikeeee -
Are you on paper logs? -
To make it easier PM, you take a 10 hour break seperates your work shifts and yes you can do it twice in one day. They don't call it "pre-trip" for nothing.
I check the brakes, suspension, etc. the big things on my post trip and a quick walk around (lights, tire pressure, 5th wheel) for my pretrip. -
Then on the PRE-trip, I check the fluid levels, lights, tires again.
During my stops, I also actually have to check my tires, as the loading dock(s) forces me to walk around the truck/trailer, so I cannot help but to check those out before i climb back into the cab.
But again, I do believe we are required to log pre and post trips. We still use a paper log by the way. But someone said, he (or she) does NOT log a post trip, which I think may not be correct.
Page 1 of 10
