is a 18 inch bolt cutter good/
Discussion in 'Intermodal Trucking Forum' started by 4noReason, Sep 20, 2014.
  1. 4noReason
    4noReason Road Train Member
    2,375
    731
    Nov 29, 2012
  3. dutchieinquebec
    dutchieinquebec Road Train Member
    1,282
    4,863
    Sep 30, 2012
    Granby.QC
    more is always better, except if it is a ticket..
  4. Ebola Guy
    Ebola Guy Heavy Load Member
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    I have a 24" cutter and it does the job without a problem. I think 18" might be a tad tough with the hardened bolts.
    4noReason Thanks this.
  5. 4noReason
    2,375
    731
    Nov 29, 2012
    the bolts are normal sized coming from containers. so i hope 24 is good
  6. SlowPoke44magnum
    SlowPoke44magnum Medium Load Member
    407
    519
    May 3, 2009
    Walbridge,Ohio
    A place I used to work had a pair of the 18" cutters and they sucked....... I prefer longer ones. But you gotta make do with what you have.
  7. Tall Mike
    Tall Mike Road Train Member
    7,243
    33,709
    Aug 20, 2014
    New York State
    Longer for more leverage..
    I got mine from Sears.
  8. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
  9. striker
    striker Road Train Member
    6,026
    6,439
    Aug 8, 2009
    Denver, Co
    got mine 13 yrs ago from Tool Zone, they are hardened steel, with replaceable jaws, about 36" long, weigh probably 20 lbs, paid $115.00 for them. Will have to post a picture of them.
  10. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    What do you guys use a bolt cutter for?
  11. Ebola Guy
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    To cut security bolt seals
    which are steel encased in a plastic shell.
    Also some rails will feed a 4 or 6 inch threaded bolt through the door latches, put a bolt on it, then bend the bolt so you cannot unscrew the bolt, so you have to cut it off.
    4noReason and MJ1657 Thank this.
