Ironman Drive Tires
Discussion in 'Ask An Owner Operator' started by RTR, Mar 1, 2019.
  1. RTR
    RTR Light Load Member
    194
    49
    Alabama
    The TA has a special on these tires $1,800. I normally run either Michelin or yokohama's but at a price like this if they last anything I believe they might be worth it?
    Looking for advice and or suggestions on these please.
  3. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    1800 installed 8 drive tires?
  4. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
    No experience with those,but I did run a Chinese Drive called long march. At 135k they had 6/32 left. They wore even and no vibration.
    blade Thanks this.
  5. RTR
    194
    49
    Alabama
    Yes
  6. mitmaks
    2,542
    2,064
    May 16, 2014
    Seems way cheap. They're not recaps, what's the thread depth?
    PE_T and blade Thank this.
  7. blade
    blade Heavy Load Member
    881
    647
    Jan 30, 2009
    Some where, Mo
    Bet they ain’t 24.5’s :(
    wore out Thanks this.
  8. Sdatruckinginc
    Sdatruckinginc Bobtail Member
    46
    20
    Jan 18, 2019
    Been runnin custom mold caps for 11 yrs blown 2 200 each and gettin in high 400s on em put 4 new yoko on blew 3 in first 2 months never bought a yoko since bought caps after that and never looked back
  9. PE_T
    PE_T Road Train Member
    Those tires look aggresive, even though they are probably for highway use. They will probably come and haunt you in the form of lower MPGs. If I did a lot of off-road, I’d buy them. Daytons, General Tire, and Goodyear Marathons are a much better deal if you’re looking for cheap tires. Those tires do not look aggresive.
  10. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    135k .. holy cow they wear fast yikes !!
    86scotty and bzinger Thank this.
  11. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    I'm not call'in you a liar but..in 43 years of experience i have never had a drive tire or steer blow out. Not saying it couldn't happen. Tried caps once..a long time back when i pulled dump bucket. Always had 54,000 to 60,000 net wt on 5 axles. Used my own casings and still caps never held up to the task. Nowdays all virgin rubber on my truck. Don't own my trailer so got to pull what they put on it. Best mileage i ever got was yokohama directional drives, 300,000 or so and that was by rotating them once. Never have tried Michelin. But 400,000, either you have a 300hp engine or are hauling feathers, or both. The Ironman tires..you get what you pay for. They probably won't blow out, but longevity will be shorter. Just my opinion.
    Vampire Thanks this.
