IPD Parts
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Real Deal, Dec 4, 2012.
  1. Real Deal
    Real Deal Medium Load Member
    468
    230
    May 29, 2012
    Saint George UT
    Does anybody have an opinion on the quality of IPD Cat parts compared to OE Cat parts. And what about the price difference between the two?
  3. RHay
    RHay Light Load Member
    107
    17
    Sep 11, 2012
    I did a head gasket on a B model that had IPD liners and pistons in it. Engine had four years on it since being inframed. Truck run about 500 miles a day daily. Cyclinder and lines looked beautful. I dont like there head gaskets. Put a OEM cat head gasket and steel spacer plate back on it. I know of another C model that has IPD kit in it that seems to be a pretty good reliable engine as well. Be aware on there engine kits you reuse your rods and have to assemble everything unlike a cat cylinder pack where its all assembled. If your going to be turning it up id go with OEM for piece of mind
    Real Deal Thanks this.
  4. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    All I have heard is very good reports about IPD products. Some of the reports are from high HP heavy haulers out of WI and the parts have survived their beatings. Also some CAT shops I buy parts from are stocking a little less these days and the reman parts are getting a horrible reputation. These factors have lead me into purchasing IPD stuff for my next rebuild. Just take a look into IPD's "crevice seal" liner and you can see the aftermarket advantage.
  5. puncher
    puncher Medium Load Member
    540
    358
    Feb 12, 2010
    Tn.
    I've used them several times and I love them. I've got my engine set pretty hot and no complaints, I've got a head gasket that blew out the back of #6 but can't say it wouldn't have done the same with a Cat gasket. The oil pan gaskets are one piece instead of the puzzle type of Cat, and they also use Cat part numbers which is handy, and they're considerably cheaper and new, not refurbished OEM.
    Kw Owners Club Thanks this.
  6. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    90
    Feb 18, 2010
    Siler City, NC
    I ordered 6 IPD injectors for my C-15. Two of them came boxed with the wrong injector (right number on box, wrong injector inside). I went ahead and installed the 4, and this engine has never ran better. After 3 sets of Cat remans, I'm feeling better. The other 2 will be here in a day or so, I'm hoping it will completely solve my problem.
  7. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    I have replaced a ipd headgasket on a turned up 5EK that blew with little mileage, mind you i think the head was not torqued down correctley i marked all the head bolts and torqued them to spec before i undone anything and got quite alot out of all head bolts, the liner protusion around where it had blown was not the greatest for an engine that had just had an out of frame done, also there liner flanges seemed to have alot of variance around them. I replaced the gasket with a genuine cat one and was verry fussy with the torque sequence and no trouble since.The rest of there c15 parts seem to handle all you can throw at them.
    That experience with ipd could be a one off combination of alot of contributing factors
    but the old saying goes if genuine is available (USE IT)
  8. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    My.02....the Ipd liners are better than Cat....I too use a Cat headgasket# 359-0908....The rest of the parts seem excellent to me....and I have used them in High Hp applications without failure....how many High performance SBC, BBC, sbf use stock pistons...very few....I have used their injectors as well and I am very pleased.... while they are not a set of Farcall's ....they are better than what I have tried to date from various vendors and rebuild shops stateside.....Yes I am an IPD dealer ....but I became one after seeing their Cat Parts hold up very well in the 1000 to 1200 rwhp range. RW
  9. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Hey Rob, I had a question or two about the IPD injectors, could you send me a PM when you get a chance. Thanks.
  10. Real Deal
    468
    230
    May 29, 2012
    Saint George UT
    Thanks for everybodys input on this.
  11. BigPerm
    BigPerm Medium Load Member
    I've sold lots of IPD in-frame kits both overseas & domestice...never had a problem...as long as a competent wrench installs same.
