Inverters and Microwaves
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Brucesmith, May 19, 2014.
  1. Brucesmith
    Brucesmith Heavy Load Member
    727
    498
    Jun 16, 2012
    There is an opportunity waiting for one of the microwave mfrs. Most trucks will not have a big enough "hole" for one of the .7 cu ft. micros that are available for as little as $45.00. The almost square size .5 cu. ft. micros have almost disappeared from the marketplace. The Sharp half pint was perfect and would run on a modified sine wave inverter. Whirlpool has a nice unit that will fit but some drivers say it wont run on a modified sine wave. Anyone find a different unit?
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Mines an Emerson from Wallyworld. 700 watt, runs fine on the modified, I just make sure to high idle when using it.
    tirednaz Thanks this.
  4. Brucesmith
    727
    498
    Jun 16, 2012
    Thanks D But yours is the same as mine. About 17 to 18 inches long. Wont fit in a Volvo, Freightliner and many more. The .5 cu ft. are only about 14 inches wide and almost the same for height and length They fit perfectly.
  5. odtill
    odtill Bobtail Member
    21
    28
    Jan 29, 2011
    I just put the whirlpool in a truck and I am having the same problem. It lights up and looks to turn on but it will not heat up. I just got off the phone with TK and he told me to get a microwave with a knob that turns it on. He said a lot of the microwaves don't put a big enough load with they first start up. I have a different one here I am going to give it a try and see what happens.
  6. sherlock510
    sherlock510 Road Train Member
    1,066
    1,057
    Jul 26, 2011
    Intercontinental.
    Hamilton Beach 1,000 watt works with truck on or off. '14 Volvo.
  7. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    Another vote for the Wally World Emerson 700 watter. Fits fine in my Volvo.
  8. freddyb
    freddyb Light Load Member
    81
    44
    Aug 22, 2013
    dumas ar
    I have 700w rival from walmart works fine w cobra 1575 inverter
  9. d281833
    881
    919
    May 15, 2012
    It fits fine in my '12 Volvo.
  10. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
  11. Brucesmith
    727
    498
    Jun 16, 2012
    loves the drive. Thanks but .7 cu ft/ micros have the door on the long side. Door needs to be on an end like the discontinued Sharp half pint. I am using a .7 but I put it in lengthwise and when I have to use it I pull it out half way and hold it while my meals cook. Works but definitely mickey mouse.
