Inverter installation at TA, how long will it take?
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, Mar 16, 2022.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    193
    60
    Apr 13, 2016
    How long would it probably take TA to put in a 1500w inverter
  3. pete781693
    pete781693 Road Train Member
    1,134
    8,203
    Oct 23, 2010
    I think it would depend on how competent the technician is. If they have someone who is knowledgeable and understands how to tie into your electrical system then no problem.
    If they have the new lube jockey attempt it, then you may need to have more electrical and electronic work performed than you bargained for??
    Jdm5jdm5 Thanks this.
  4. D.Tibbitt
    141,058
    Probably about 26 hours with 5 hours of waiting time. They will probably even open your hood just to make it look like they're doing something...
    But really. It is not rocket science to do it yourself. Just use the correct gauge cables
  5. Allow Me.
    10,642
    12,108
    May 28, 2009
    Rancho Mirage, Ca.
    You must be sitting at a T/A doing a 34 and wondering how to spend your paycheck, right ?
    WesternPlains, MOBee and TripleSix Thank this.
  6. TripleSix
    127,976
    ZIP ZAP KAPOW!!!!!!!
    citrus5, Badmon and homeskillet Thank this.
  7. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
  8. Moosetek13
    Moosetek13 Road Train Member
    14,521
    17,999
    Nov 1, 2010
    Burnsville, MN
    Why don't you go in to a TA and ask them directly?
    tscottme Thanks this.
  9. Moose1958
    Moose1958 Road Train Member
    15,093
    33,183
    Dec 17, 2010
    Williesburg, Virignia
    The actual installation should not take long. The thing is unless you are an OO you might want to check with the carrier you drive for to see if they want one on their truck. Most carriers already have them on. The risk of fire arising from a shotty install is VERY great! Again unless you actually OWN the truck follow the carrier's policy!
  10. citrus5
    citrus5 Bobtail Member
    Moose gave you the best advice.I would do it myself if you are a o/o but if you one of the trucker that drives for a company then yes its best to follow company policy you dont want to have a faulty install to burn down a 100 thousand dollar truck.I am a retired driver trainer of 32 years [Blondie]
  11. D.Tibbitt
    141,058
    It really isn't rocket science. Install the correct gauge cables and there won't be any risk of fire
