International ProStar triangle is on and red light stop engine beeping but truck isok
Discussion in 'Experienced Truckers' Advice' started by Samall02, Jun 17, 2014.
  1. Samall02
    Samall02 Bobtail Member
    7
    This morning
    I drive a 2011 International ProStar Plus. It gelled up, but its good now. Only problem now is I have a red stop sign symbol on my dash with an explanation mark and my dash says "Shutdown Engine." The truck keeps beeping from the warning lights. Beeps 97 times a minute. Does anyone know how to fix this. Really need help on this and you fellow drivers always know how to get me rolling again. Serious comments only please
  3. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    The fuel gelled up?
  4. Samall02
    7
    What to do I changed turbo actuator and its still on and beeps.
  5. Samall02
    7
    Actaly International service told me that and they clean it paid $700 but nothing fixed still on
  6. Moosetek13
    Moosetek13 Road Train Member
    14,521
    17,989
    Nov 1, 2010
    Burnsville, MN
    Must be in Alaska. I don't think there is anywhere else that could have been cold enough.
    The fact that you have that warning indicates that there really is something wrong, even if you don't think so.
    Get it to a shop where they can check the codes.
    If it is nothing, they can reset it.
    Do it now before the engine de-rates, because you may be traveling at 5 MPH max.
  7. Samall02
    7
    They told me in International service that and they clean it I paid $700 and now my yellow teiangle is on and stop engine too and beeps drives me crazy
  8. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Don't worry about anything suggesting the contrary, truck isok
  9. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    If you're going to pick at someone's spelling you might want to proof read your own post for punctuation.
    I'm going to make a guess that the "gelling" he's referring to is crystallized DEF clogging the injection valve. Whatever it is I'd be getting it back to a dealer asap.
  10. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    The triangle means " look down here" at the digital display. At a minimum you need to do a parked regen. With the engine running push and hold the parked regen switch until the engine starts high revving. The regen can take as long as 45 minutes. Your gelled fuel caused a partial fuel burn which soot clogged your DPF.
    If that doesn't work the DPF will have to be removed and baked to burn the soot out. Shop around and you should be able to find a better deal than $700.
    Moose, it was 30* in Battle Mountain, NV last night and there was snow on the surrounding hills this morning.
    Keith, the 2011 Prostar has the ISX 400 CUMMINS the last of the non DEF engines.
  11. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    And you obviously didn't understand his sarcasm.
