International dt466e air compressor questions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jrb81, May 29, 2017.
  1. Jrb81
    Jrb81 Bobtail Member
    5
    May 28, 2017
    I have a 02 International 4300 LP with a dt466e and it is a non air compressor truck that I'm installing air operated PTO and air operated dump pump and I need to know what all is involved in putting a air compressor on a truck that wasn't Factory equipped with one. I don't have a truck with air around here that I can look at 2 see everything that I need so I need kind of maybe a parts list or some insight on hoses oil lines mounts and stuff like that. I know a little bit about a lot and a lot about a little bit and unfortunately this is one of those things that I know a little about a lot so any insight would be greatly appreciated.
  3. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    its been a long time sense iv looked at a 466e im thinking they may have had belt driven compressors, i very well could be wrong on that though.
    i would think though that for just a pto and air over hydro valve a small electric compressor and small tank with a little pressure switch would work just fine.
    Jrb81 Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    I thank you are going about that the wrong way. I have a couple of those midsized trucks with hydraulic brakes. One has an air ride cab with its own little electric minnie air compressor for the cab air bags. The other is a Larado Kodiac with air suspension. It has a larger electric air unit. I cannot recall the name but I thank they are in Sioux Falls SD. Had to work on it once and called them. Great people to work with but had to get the part through a distributor.
    Kodi and I followed a star with Jesus is Lord out of Memphis last week through Bham in the rain. Hope ya'll did not mind me tagging along. Jesus was riding, thanks for the ride.
    Heavyd and Jrb81 Thank this.
  5. Jrb81
    5
    May 28, 2017
    I didn't even think about going electric, I really appreciate the response. Thanks a ton
  6. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    You are welcome. I did not thank of it ether my trucks came that way.
