International 9100I Guages on dash not working Help diagnosing?
Discussion in 'International Forum' started by Farmer Ray, Feb 3, 2022.
  1. Farmer Ray
    Farmer Ray Bobtail Member
    Went to start truck and oil pressure,water temperature,voltage,fuel Guages won’t work.The dash lights work good and oil pressure and water temperature lights stay on.Truck starts fine.Will this be a dash cluster problem or could it be something else?Thanks
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Oil pressure, water temp and voltage are feed data from the engine, while the fuel gauge is just a variable resistor type sender in the tank with different wiring. I would suspect a bad center tach/speedo module. If you can find someone with an International 9000 series, you can swap the center dash piece to test it.
