International 4300 AC compressor kicking in and out
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kentuckynet, Jun 23, 2020.
  1. kentuckynet
    kentuckynet Bobtail Member
    8
    Nov 3, 2012
    Hello my international 4300 2002 model, the ac is about as cool as its ever been, has never been cold.
    The ac compressor is kicking in and out about every 10 seconds, i hooked uo gauges and watched the fluctuation, low side would drop to 30 and the high side being 150 then it would go to 50 on the low side and 120 on high side, this would repeat every 10 seconds as the compressor kicks on and off.
    Any help would greatly be appreciated, the temperature outside was around 85 and humidity around 50%
    Idle was around 2000 rpm
    thanks so much for your time
    mack
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Maybe someone more knowledgeable will come along and be more help.
    Does your truck have two thermistors, sensors in the a/c lines, at the RF of the fire wall? Those are a common failure item in my experience. Use the top right search block and check that out.
    To my understanding those are tied into the cab control module. If it does not like its sensor inputs it cuts things off.
    There is probably a pressure switch or two as well. Best checked with a voltmeter. A test light can knock out some of this new electrical stuff. If you see a switch with three wires to it do not use a test light unless you know it is OK.
  4. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    AC is computer controlled in your truck. You need Diamond logic builder software to see what is going on and what the body controller is seeing. Your truck will be the orifice tube type with the cycling clutch style of ac operation. So off and on all the time is normal operation for that. If you do not have access to the software program, I would start with recovering the system and recharging with the proper amount of R134 which is 1.9 pounds. Also on that, the kick panel below the breaker panel in front of the passenger seat must be installed properly because it forms the outside layer to the blower box. If it is not on right, air will just blow around the whole system and never get nice and cold.
    BoxCarKidd and spsauerland Thank this.
  5. Inderjit
    Inderjit Heavy Load Member
    716
    703
    Sep 17, 2017
    As long as Diamond Logic Builder is included you are good to go.
    However Diamond Logic Builder will not tell you the temperatures or pressures so it is
    not a big help.
    It sounds like the system is building too much pressure but your gauge readings say otherwise.
    I suspect the pressure transducer has failed and is shutting the pump down for over pressure
    when the pressure is at 150psi. It should shut the pump down at 275-325psi.
    The pressure transducer is on one of the lines going to the grill denser.
