Inter-axle lock ..."Eh, you don't need it"
Discussion in 'Experienced Truckers' Advice' started by dogtrucker, Jan 26, 2015.
  1. dogtrucker
    dogtrucker Road Train Member
    1,102
    1,138
    Sep 10, 2012
    my truck
    That is what the maintenance coordinator and my dispatch supervisor tell me. I drive in Illinois and have plenty of experience with icy roads where trailers fish-tail and and the drives can spin out from under.
    I discovered my IDL was not working last week when I got stuck in ice and observed that only one wheel was spinning. To my surprise, the lady who sits in the office with no mechanical training or driving experience told me that: "we don't want drivers to use it because they break and we don't want to repair them". ...Wow
    According to Teamrunsmart.com (Freightliner's forum for authoritative answers about their equipment) what causes damage is not engaging the lock and allowing one axle to spin out.
    Dispatch and Maintenance strongly resisted my efforts to make an issue of this and would not, at first allow me to speak with anyone in authority about my safety concerns. But I persisted. I put in writing "for documentation" that I was not being allowed to get a repair, that I was pressured to drive into a blizzard with out this safety feature and included authoritative citations from Freightliner.
    The next day I got a call from the owner of the company who said, basically, "yeah, go get it checked out". He is no slouch on Freightliners - he owns 600 of them and specs the truck himself - but called his Meritor rep to get clarification on the info i provided and advised me how to have it properly tested. I feel better now.
    As I pointed out to my dispatcher: In the office, safety is an administrative concept; in the truck, safety is a personal and immediate reality.
  3. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    Well if it worked in the first place, then you would not be talking to a dispatcher who has no clue what they are doing. Yep, tow truck time there.
  4. BROKENSPROKET
    BROKENSPROKET Medium Load Member
    675
    172
    Jan 22, 2011
    Wisconsin
    dog-c Thanks this.
  5. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,905
    47,744
    Dec 8, 2012
    hunting...../ retired
    Kudo's to you for holding their feet to the fire and sticking to your guns , any such issue should be resolved not matter the cost.
  6. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    When you were spinning one wheel, did you have the locking drive axle control activated? Even when turned on, And do not activate it unless the wheels are all turning at a slow speed or stopped. Turning it on when spinning, can produce a result you will not like! And even when turned on, it only locks the two differentials together, but unless you have full lockers, like positive traction, one wheel may spin on the front axle and one on the rear axle. Only with full locking differentials will the axles spin both wheels together and then the interaxle locking ties the two axles together. When all axles are in locked position, you will have a problem in turning.....
  7. BROKENSPROKET
    675
    172
    Jan 22, 2011
    Wisconsin
    With it off, one should have a front axle AND a rear axle, right? Then when it is activated, then one should have 3 axles, right? That is the way I understand it.
    I was told that forgetting it on and running highway speed can blow it out to.
  8. Hammer166
    7,350
    26,445
    Aug 18, 2007
    ~8600+' and loving it!
    No, with it unlocked, only one corner will spin. Locking the divider locks the front and rear axle together so that at least one wheel on each axle will spin. Reread mnmover's post.
    kylefitzy and Cetane+ Thank this.
  9. Saturday
    Saturday Medium Load Member
    374
    385
    Dec 19, 2014
    Why don't they just make all the drives all wheel drive all the time, or is pulling a trailer with 30k+ pounds of freight unrealistic with all wheel drive?
  10. HDFatboy
    HDFatboy Light Load Member
    288
    199
    Sep 22, 2011
    PA
    What they said^^
    With it locked in, two wheel positions will spin, one on each drive axle. IE: Front Left and Rear Right
  11. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    It would be a bugger turning corners. Not to mention wrecking the differential because the inside wheel needs to slip. Same as a car. I suppose they could design some torque sensing thingamajig like Mercedes cars have but that's bound to be expensive.
    To the OP: Do they expect you to chain up?
