Installing mini round led lights
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Jcurran90, Mar 10, 2018.
  1. Jcurran90
    Jcurran90 Light Load Member
    53
    8
    Apr 29, 2016
    Got a bunch of mini I think 3/4 round led lights that am looking to install on my head rack ... what drill bit have people used to drill thru the steel ??? I tried one but it didn’t have a chance dulled after 15 seconds lol has anyone done this and if so what drill bit did you use ?
  3. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    I would recommend a cobalt drill bit
    Or start there then use a step cobalt drill bit.
  4. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
  5. AModelCat
    154,214
    Good drill bits and cutting fluid. For bigger holes I like to pilot drill the holes with a 1/4" bit and then either follow up with larger bits, or just ram a good HSS tapered reamer on a drill through the pilot hole.
    blairandgretchen Thanks this.
  6. mslashbar
    mslashbar Medium Load Member
    599
    802
    Jul 22, 2009
    elizabeth,co
    You're going to have to start with a small bit and then work your way up. It's not going to be easy with a hand drill going that big, I would recommend a 3/4 hole saw.
  7. AModelCat
    154,214
    Hopefully where you are drilling these holes isn't structural!
  8. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    Took the Words out of My Mouth...
  9. rolls canardly
    rolls canardly Road Train Member
    1,596
    3,726
    Feb 7, 2009
    mt. pocono. pa.
    If you are drilling in steel, get a magnetic base drill and hole-saw, layout/center punch it first to locate,
    Then use a bigger center punch and whack it real good, to give pilot somewhere to settle into.
    Spin the chuck backwards by hand first, to make sure drill tip is centered in punch mark.
    Now verify location of drill tip in this crater, flip on the magnet, and drill away.
    Try the size and fit first on some junk steel. That's the easiest way; after several it's nothing.
    I did this up the sides of my Freightliner Rollback bed, thru 6X6X1/4" steel angle, every 2 feet.
    Reason for edit: just woke up
  10. sxdime
    sxdime Medium Load Member
    409
    551
    Nov 9, 2010
    Elkton MD
