installing breather lights 2007 kw w900 day cab
Discussion in 'Experienced Truckers' Advice' started by devan, Dec 26, 2011.
  1. devan
    devan Bobtail Member
    sweet home oregon
    I can't find any instructions for installing breather lights on my truck....where to tap into switches and all that good stuff...also I want to install some mirror turn signals...also no info to be found....if any one knows of a link or can describe the process that would be amazing....thanx in advance for any help
  3. special-k
    special-k Road Train Member
    1,523
    3,259
    Dec 27, 2008
    Southern Ontario Canada
    If you look around under the hood you might find you have a factory wiring harness already there. My Pete came prewired for air cleaner lights and side clearance lights. They were labelled and tucked up tight to the firewall.
  4. Moosetek13
    Moosetek13 Road Train Member
    15,164
    19,389
    Nov 1, 2010
    Burnsville, MN
    So, breather lights.
    Do they help you to breath easier, or do they actually breath on their own?!
    Be cool if they actually breathed on their own.
    You might see vapor expelling from the lights in cold weather.:biggrin_255:
  5. Moosetek13
    15,164
    19,389
    Nov 1, 2010
    Burnsville, MN
    Add a cool Darth Vader sound effect, and you would have a truly 'monster truck'!:biggrin_2553:
  6. brenes-built
    brenes-built Light Load Member
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    I have a 99 pete 379 and wanted to replace the breather lights.. I ran into a problem where the bottom bolt on the passenger side just spins.. How do I get ahold if it from the inside..
  7. Marc Letourneau
    Marc Letourneau Light Load Member
    119
    26
    Feb 23, 2012
    Worcester Massachusetts
    The truck should be wired for it already.. The 2007 W900L we have has one of the switches by the driver side door controls them.
  8. Rollover the Original
    Rollover the Original Road Train Member
    3,206
    2,713
    Jul 1, 2009
    Springfield,MO
    You might need another hand in the operation! If you can't reach around the hood to the bolt or it's behind the footwell paneling you'll need someone to help.
    brenes-built Thanks this.
  9. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    Just depends whether the truck was speced with the optional harnesses for the breathers. If not and it was me i would not tie them into the other lights. There are plenty of hot and cold leads under the dash,just add another switch if there are no spares. As far as the mirror turn signals some where in that dash are the leads for left and right. They should be labeled,so should there be leads for the breathers. May be marked as optional. Go to the KW forum there is a parts guys who can look up your VIN and tell what you have and don't have. Sorry did not notice how old this was.
  10. Mr Ed
    Mr Ed Road Train Member
    1,380
    1,630
    Apr 6, 2009
    Retired in Taunton Ma
    I replaced my headlights with airplane landing lights.I see EVERYTHING now,of course,no one else does.
