Installing battery cut off switch
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lokahi117, Dec 17, 2013.
  1. lokahi117
    lokahi117 Light Load Member
    86
    7
    Oct 7, 2012
    Last time I went home the truck drained the batteries and I had and did again upon return triple check everything was off that could have been on. So what I'm wanting to do is install a cut off switch but I have quite a few aftermarket things apparently wired up to each of the different batteries. Would it somehow harm anything if I was to consolidate these to just the one battery post set so I can install the isolate inline of that post set and thus be able to kill everything for sure with the flick of a battery shutoff switch? Because I need to make these trucks very easy for new guys we hire to be able to follow a simple checklist in order to get the truck prepped for sitting while they go home.
    Though im also thinking I may advise the owner to put tempa start systems in to be an ultimate back up catch all safety net. Cause a road call here for a frozen truck can run you 2000 easy. And that's just the cost of the call not to mention the lost productivity. So it becomes very cheap by comparison.
    Any thoughts on the cutoff switch guys.....or the tempa start? Does anyone use a tempa start? Never mind....new thread so others can learn about it as well.
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    The only problem with cutting everything off is that many of the electronics now have heaters on the circuit boards, which may be what is helping to drain your batteries. Shutting everything off could let something freeze, condensate, or some other problem that they were trying to avoid by installing those heaters. It might also void any warranty.
    You might want to be certain your batteries are up to spec, and the best way to be sure is to test each one individually. testing them as a group might give you results that they look OK, but one bad one will drag down the others as they sit.
  4. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Are you positive the batteries arnt freezing?
  5. bull hauler
    bull hauler Medium Load Member
    300
    80
    Apr 23, 2012
    Get new batteries problem solved
  6. ENR
    ENR Light Load Member
    254
    50
    Oct 8, 2009
    Ontario
    if it's $2000 for some one to come out and get you started you are a perfect candidate for one of those maxwell start modules
    something to look into
  7. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    One thing that is very easy to check for when the batteries drain down is the alternator, after you shut the truck down take a wrench and put it across the pulley if it is attracted the internal regulator is not shutting down. You want to find the parasitic drain,anyway.
    Ground isolation switches are not hard to install, you need to find a practical area to mount them preferably out of trie spray, and have some #2 battery cable and solder up some new cables. Two switches work the best.
    Just a thought!
  8. rick3305rick
    rick3305rick Light Load Member
    50
    21
    Sep 18, 2013
    $2000 ? Ill come get it started for you. Ive got 4 batteries and on my way. lol
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Some trucks defend themselves against drains using a 3 and one system where one battery is controlled by computer and isolated from the other three so that no matter what happens there theoretically is one big battery able to keep a charge.
    I worry that in today's era of Computer Trucks far in excess of it's capability to be almost "Alive" for lack of a good word comparison they need those batteries to feed on while sleeping with everything off.
    If you are trying to install one or two kill switches big enough to make sure nothing is being drawn on those batteries, I have a feeling you are not fixing the actual root cause of your power loss. Somewhere there is power flowing when and where it should not be.
    That leads me to the fuse stack. small amp fuses all the way up to god knows how many amps, 30? 50? etc.
    Pull a fuse. Put a tester across the two slots it came out of. If you see power flowing then that is probably your problem and it's affected device such as the radio fuse or the cigerette lighter fuse etc. I don't know exactly remember how to set up a multimeter to read power flowing when it should have ZERO power flowing. It's best left to someone else who remembers.
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    That post was 3 years ago, I think he may have found someone else. :)
