Installing Air Bag Pressure Gauge?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sgreer78, Aug 19, 2008.
  1. sgreer78
    sgreer78 Light Load Member
    251
    62
    Jul 26, 2008
    St Louis, MO
    When installing a pressure gauge for drives is it possible to just "tee" into the air line that goes to the air dump valve, or do you have to run a separate line from the air bags to the dash and then to the gauge? I'm either looking to just throw an OEM Freightliner gauge in, or maybe a weigh rite depending on pricing.
    BTW, Freightliner quoted me "around" $550 to do this:biggrin_25516:
    Thanks
  3. 25(2)+2
    18,772
    46,347
    Sep 18, 2006
    the road less travelled
    I don't know, I was told it was unnecessary, but when a sealed load has shifted without your knowing, an air gauge would prevent lots of trouble. A tractor I drove once had the gauge in the line coming from the air suspension, it would have been inserted with a t, liquid filled gauge, but you have to be equalized before reading it, the suspension has to be at ride height. That wouldn't cost much, and there is no reason it wouldn't be accurate. It had to be read from the outside, it was much better than nothing.
  4. sleepless nights
    sleepless nights Light Load Member
    69
    14
    Jul 26, 2008
    Canada
    I beleive you need to tee into the air line between the levelling valve and the air bag. The factory's usually use a tee right at the air bag and run 1/4" synflec line up to the gauge. Does your truck have a data display in the dash?
  5. old-school
    old-school Light Load Member
    203
    87
    Jun 18, 2007
    south western ohio
    it is very simple you go to the right rear airbag and put a tee in it and then run your airline through the frame to the firewall find a place to go through I used a air gauge off of an old air commpresser. and right around 60 psi is for the most part 34,000 lbs I did mine for 30.00and about 1hour hope this helps. and no you can noy tee into the dump valve it does not work tried it already.
  6. sgreer78
    251
    62
    Jul 26, 2008
    St Louis, MO
    Thanks. I'll do that. I'll get the weigh rite gauge, and throw it in.
  7. tesla4all
    tesla4all Light Load Member
    176
    33
    Dec 8, 2008
    Southeastern US
    Now to tie in your trailer tandems!
  8. AJWESLEY
    AJWESLEY Bobtail Member
    12
    Im going to the same. Good I read this the Tee go on the right rear air bag. Air bag levelling is close to my left air bag. I have a international 9400 I. I will put one on my speed axe Trailer. use the right rear air bag. That levelling is also on the left side.
  9. pawpaw1
    pawpaw1 Medium Load Member
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    I bought the Right weigh gauge . Had it for about 8 months , never had to adjust it , after setting it up. I pull a tank , never saw anything do such a good job, without constant fiddling . I pull different trailers , all the time. So , it's only on the tractor. That's what I was concerned with , anyway.
    Mines a KW , the leveler is about center , but to avoid a sharp bend , I also attached mine to the right rear , because of the way I ran the air line back.
  10. KWJams
    KWJams Bobtail Member
    12
    8
    Jun 22, 2014
    Any tips for spread axle trailer installation?
  11. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    2 gauges
    AModelCat Thanks this.
