I need to put a male PL 259 on the end of my coax. I purchased 2 different ends from the truck stop, one is a crimp-on and I'm not sure about the other one but it might need to be soldered on.
How do I install these? I do not have a coax crimping tool should I go the crimp route, can a regular wire crimping tool be used?
Thanks
Installing a male PL 259 connector
Discussion in 'CB Radio Forum' started by zx150, Jun 1, 2016.
You sure the coax isn't a mini 8 where one end is soldered and other end you screw on?
It's the clear cable they sell at all the truck stops. I've attached a photo that shows the cable but not the end, looped so it won't drag.
Wow, that photo had me baffled for a while, it looked like you ran over some loose coax and got it wrapped around the hub of your roadster. Or you were giving new meaning to radial tire LOL. I get it now, its run off the back of the spare tire mount...
I prefer solder connection, my thought being if a single run of coax can be ruined in a door jam in a single door slam, crimping the coax must also alter the impedance ohms. <--- Someone better informed please comment?rabbiporkchop Thanks this. -
If you have not done this before, find someone to do it for you.
rabbiporkchop and Ougigoug Thank this. -
Went the solder route and it seems to be working out alright.TheDude1969 Thanks this. -
The finished installation.
Thanks for the help.
Edit: I just realized I snapped those photos before I put on the 259.Attached Files:
Just out of curiosity was it hard to reach acceptable SWR with you set up?
Not weathertight, but doesn't damage dielectric.
I even got a set of extra dies for building custom spark plug wires.
burnsey and TheDude1969 Thank this.
