Inspiration comes standard Stryker SR-A10 CB antenna
Discussion in 'CB Radio Forum' started by Jasonkip, Mar 22, 2018.
  1. Jasonkip
    Jasonkip Bobtail Member
    28
    6
    Dec 12, 2017
    California
    Got an A-10 mounted this morning on a thru roof mount. Using a mfj analyzer and then a cross-needle for reflect monitoring, the Stryker tuned better than the competitor it replaced. At 150 watts out, Stryker had about a watt of reflect showing. The Sirio's lowest tune had 2 watts reflected. The analyzer also showed a better match with the SR A-10. More testing to come but I think sharing is caring.
    [​IMG][​IMG]
    [​IMG][​IMG]
  3. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    I think the forum owner should charge him for advertising..
  4. Jasonkip
    28
    6
    Dec 12, 2017
    California
    Sorry? Where is the advertisement?
  5. Jasonkip
    28
    6
    Dec 12, 2017
    California
    I can't see any advertisement here. Mr. Delta5
  6. Ridgeline
    22,098
    113,138
    You are focused on one product, talking like you are promoting it as the end of all the competition and for some without merit, so yes it seems like an ad.
  7. delta5
    1,193
    7,404
    Sep 9, 2010
    I'm in charge of paid advertising.
    Please enter your credit card number here: ________________________ exp ______
    417bigK, BTShepp and jessejamesdallas Thank this.
  8. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    From some of the negative posts I've seen on that antenna....I think it needs all the FREE advertising it can get!
  9. delta5
    1,193
    7,404
    Sep 9, 2010
    But it looks like a Vulcan mini gun!
    jessejamesdallas Thanks this.
  10. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
    Kinda hard to beat the Francis Amazer.
    Good luck finding one.
  11. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Look's like a 102" whip...
    OK...(looked it up) I use to have one of those back in the mid 70's...looked like a 102" fiberglass whip, but was a foot shorter...Problem I had with them was the tip would end up splitting from banging stuff and the wire would start coming out...use to stick airplane glue on the tip and wrap it up with black electrical tape to fix it!:D
    rabbiporkchop Thanks this.
