Inside trailer tires
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by johnnyboyloco2500, May 3, 2020.
  1. johnnyboyloco2500
    johnnyboyloco2500 Light Load Member
    67
    12
    Dec 7, 2015
    Lebanon,Oregon
    So greatdane flatbed,
    297/75/22.5
    Left side inside tires. Hop scotch
    Firestone tires are wearing on last 2-3” of inside tire. Do belive shocks and alignment. any info helps
    Thanks
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Have the wheel bearings adj. with a end play tool, then you will see a big diff. in how long the tires last?
  4. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    I had one doing that when i got this trailer. Turns out the valve stem was leaking going down the road letting it run low. Then when stopped it aired back up with the auto inflator.
    SilverBulletBand Thanks this.
  5. Rideandrepair
    17,224
    55,904
    Aug 8, 2015
    Inside of inside tires, on my Trailer was from bad suspension bushings, flat spots, erratic wear across tread, from loose bearing. Bad bushings also caused a lot of weaving/dog tracking in different directions.
  6. JonJon78
    JonJon78 Road Train Member
    7,042
    37,583
    Jul 1, 2018
    How long does bushings typically last on a trailer? I've got a spread axle flat and have the flat spot issue on the passenger side front axle inside tire. But noticed today seems the outside tire is starting to do it as well.
    Trailer is 2 years old. Henrickson suspension.
    Rideandrepair Thanks this.
  7. Rideandrepair
    17,224
    55,904
    Aug 8, 2015
    My last trailer was 13 yrs old when I replaced them, they were shot. And the bogie was cracked. It was a waste of money to have it fixed. But I didn’t want to buy another trailer. Ran it 2 more yrs. till the floor gave out. I doubt yours are bad already, even being a spread.I would guess they last at least 6 or 7 yrs. probably more like 8 or 9. I really don’t know. Mine started weaving in the lane, going straight down the road. Dog tracking one way, then the other. Progressively got worse. Might just need an alignment, but I would make sure the bearings not loose. Check it for play.
    JonJon78 and 650cat425 Thank this.
  8. JonJon78
    7,042
    37,583
    Jul 1, 2018
    Think the problem was staring me right in the face, but I wasn't looking...
    Bad shock.
    Lemme play mechanic for 10 minutes...
    Good as new, change both of em.
  9. bad-luck
    bad-luck Road Train Member
    3,252
    5,956
    Nov 16, 2013
    Baltimore, Maryland
    Check Bushings. Also when the wheel bearings wear, the nut becomes loose and needs to be tightened
