injector wiring harness
Discussion in 'Trucks [ Eighteen Wheelers ]' started by marmonman, Oct 24, 2011.
  1. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    Does it make a difference witch way the injector tabs are installed on the injector?
    I cant see any difference between one side or the other! I don't know if there is a hot and a not or if the injector just needs juice to either side to fire off.
    I do know I have more than one set of wires that the insulating coating is cracked and broken !!
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    one more time... what engine, what year....
  4. marmonman
    1,417
    2,842
    Dec 14, 2009
    central illinois
    Sorry about that ! It is a 1996 3406E model cat 5k66650 . I am installing a new wiring harness for the injector and Jakes .
  5. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    I'm not familiar with the Cat, but with a detroit, the wiring harness is designed for lenght to lay out which side and which one to put the wires onto. Also has a locking hook in one direction.
  6. power freak
    power freak Light Load Member
    220
    60
    Apr 23, 2009
    They are numbered one through six on the harness and it doesn't matter which way they go on. But the way they have the slots configured on the end you can flip them to make them point in the correct direction.
  7. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    No it does not matter which slot on the harness goes on which injector post. The injectors utilize AC voltage. I would flip the harness end over especially when I swapped injectors to make it easier to install.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    When you tie in the harness to the separator plate the wiring will lay a certain way. You want it to be clear of moving parts and have as little stress as posible. I use to tie it in loosely, then put it on and do a test installation, and be sure the injector wiring is positioned properly then just flip it over and cinch it down, and trim all the ties.
    Just a thought!
