Injector o ring question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bruce25, Dec 16, 2023.
  1. bruce25
    bruce25 Light Load Member
    150
    90
    Apr 16, 2014
    Series 60 12.7 pre emissions loss of power misfire and coolant pushing out of reservoir. my first thought was sunk liner head gasket. But after checking injector #5 out bolt holding it was loose big o ring was completely destroyed and graphite crush washer was missing. Could this be the cause of my issue and not blown head gasket?
    Here is the photo of injector and o ring
    btw crush washer on it was just me checking something out it wasn't there when I took it out
    Rideandrepair Thanks this.
  3. Big Road Skateboard
    5,698
    29,732
    May 2, 2021
    No. Look at the cup, it May be cracked
    Coolant surrounds the cup, not the injector
    Loose hold down will definitely cause performance issues, allowing compression into the fuel
    Looks like you have the injectors out. Pressurize thr cooling system and you can see if any cups are leaking
  4. bruce25
    150
    90
    Apr 16, 2014
    Ok I didn't know coolant went around the cup I thought it was injectors. What's the easiest way to pressurize cooling system?
  5. Big Road Skateboard
    5,698
    29,732
    May 2, 2021
    R
    Rent a pressure tester from an auto parts store
    Oxbow, bruce25 and Rideandrepair Thank this.
  6. bruce25
    150
    90
    Apr 16, 2014
    Ok I will buy a kit since it can arrive here tomorrow. I think it makes sense now that cup or cups could be bad if so then compression would enter be entering cooling system correct?
  7. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    head needs to come off
  8. bruce25
    150
    90
    Apr 16, 2014
    Yea that's the sucky part I change the head once 4 years ago
  9. Big Road Skateboard
    5,698
    29,732
    May 2, 2021
    Yes. A cracked cup can cause compression in the cooling system, while also allowing compession to enter the fuel system.
  10. Diesel Dave
    8,530
    23,529
    Jan 20, 2010
    Hesperia, Ca.
    Isn’t there a member here that is a machinist that can replace injector cups without removing the head ? I forget his username.
  11. Big Road Skateboard
    5,698
    29,732
    May 2, 2021
    60 series cups are set from the top, but swaged and machined from the bottom. There may be new methods I don't know of though. CAT and Volvo cups can be done up top. Not sure of N14, never seen one fail
