Injector Cleaners?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 2hellandback, Jun 18, 2009.
  1. 2hellandback
    2hellandback Heavy Load Member
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    Im looking for a good injector cleaner, the other day an old boy told me acetone 1 qt per 50 gal fuel was the best injector cleaner,,, Hmmmm
    What are some good ones to use?
  3. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I figure if there were something that worked great as an injector cleaner some company like Lucas would know about it and incorperate it into there product. I'll stick with things labeled as injector cleaners. Also, some things that "old boys" tell you may work on "old trucks" but not your truck if it's newer.
    ....and to answer your question, I have heard of using ATF
  4. 9 Axle
    9 Axle Light Load Member
    147
    23
    Feb 7, 2009
    Purdon, Texas
    Ummmm, a quart of ATF in a 100 gallon tank does a really nice job cleaning the fuel system. Just make sure that it's not red,,,,,, the "fuel police" don"t like red fuel !!!
  5. 05chopper
    05chopper Light Load Member
    169
    22
    Dec 25, 2008
    USA
    I wouldn't use ATF in the fuel! Show us just how clean your system is. This is another old tale that needs to go away Man... I'll be the first to post it... ARE YOU PEOPLE NUTS!!!
    As many of you have stated... "in the old days... and old timer said & used..." is just that "old days"... these are the new days!!
    Todays engines have tighter tolerances, operate with very strict computerized systems and there are many quality products that would or do the same job without the risk of problems or voiding your warranty.
    Why you should not use ATF in your oil and or fuel system.
    1) $40,000 and you want old school advice?
    2) ATF in your oil will loosen large deposits and cause problems - should have been changing oil and filters more often it would seem?
    3) ATF in fuel will look like dyed fuel or AG fuel
    4) ATF will dilute fuel and change it's properties and is not recommended by any fuel company I know of or any current truck manufacture as well.
    5) Some companies even question the use or even if its necessary to use fuel additives as it is, but many of us do. Some people have claimed that they NEVER have and still get 300,000 - 500,000 on their motors?
    Common sense would or should dictate that adding oil modifies to your oil chnages the characteristics of the oil and adding ATF to your fuel changes the fuel's as well - for the worse (or no real benefit at least). At least fuel treatments designed for diesels is just that designed for diesels.
    Except for antigel and fuel conditoners, nothing but stock air filters, exhausts and and the like for me.
    Good luck to the rest of you.
    Rounded_nut Thanks this.
  6. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    stanadine made by an injector manuf
  7. road2trucking
    road2trucking Bobtail Member
    7
    yea i dont use fuel injectors.....why use 2 condoms,if u can use one...u know i mean...just get oil change after 12000 miles
  8. Rookie O/O, vet driver
    Rookie O/O, vet driver Light Load Member
    87
    68
    Oct 17, 2008
    Port Clinton, Ohio
    Howe's/Lucas/Liquid muscle say to add their products at every fill-up. At $15+ every fill-up it gets kinda expensive. Do the math. If, after 400k miles you have an injector problem you should have around a $4000 (based on 250 gal. each time # 6 mpg)surplus in your maintenance (sp?) fund. Provided you've shunned these products, that is. I'd say that would be enough money to replace your injectors. The only additive I'd recommend is something for cold weather gelling. It's worth the paying for the additive to avoid a tow/thaw-out. (field tested). And, as far as oil additives, my opinion is that the oil is stable enough. As long as you change it regularly. Most of that stuff winds up in the bottom of the pan, anyway.
  9. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    Couldn't have said better Rookie O/O.
  10. Diesel-Power
    Diesel-Power Bobtail Member
    BC
    I have used acetone in the past but never more than 2 ounces per 10 gallons. I think using 32 ounces per 50 gallons of fuel you are asking for trouble. I don't risk it anymore and use a good commercial additive which is certified by the EPA.
    Joe
  11. rodknocker
    rodknocker Road Train Member
    1,242
    584
    Dec 18, 2008
    Southeast
    Just use straight diesel fuel and change your filter regularly unless you live in antarctica.
