Inframe Kits
Discussion in 'Trucks [ Eighteen Wheelers ]' started by grizzly, Jul 27, 2010.
  1. grizzly
    grizzly Medium Load Member
    599
    432
    Aug 27, 2008
    Layton, Ut
    I am going to inframe my 3406E CAT and was looking at the Mahle/Clevite kits. Does anyone have any experience with these? I know they make some of the hard parts for CAT. They also have a better parts warranty.
  3. e500gvr
    e500gvr Light Load Member
    125
    32
    Aug 21, 2006
    Bloomington,MN
    Check the Cat site: www.ohe.cat.com
    They have a bunch of new kits for the 3406E at savings of 10 to 40% less than buying seperate parts. Plus , you can add ESC if you want.
  4. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Mahle/Clevite kits are good, I used a PAI kit for my Cummins as their price was better and quality is not an issue (they make Mack kits)
  5. Rafferty
    Rafferty Bobtail Member
    26
    6
    Jan 26, 2008
    Iowa
    Just because they make some parts for Cat doesn't mean they are the same part. Cat has many suppliers that make parts for them to their specs. Really look and compare the warranties. If that part fails, will Mahle/Clevite pay labor. Cat will if the engine is repaired in a Cat auth shop. That is even if you do the work yourself.
  6. grizzly
    599
    432
    Aug 27, 2008
    Layton, Ut
    I did check the warranty and yes Mahle/Clevite will pay for the labor to replace any part that fails. They have a 2 year warranty and CAT only has a 1 year. I ordered the Kit a couple of days ago, when I install them I will let you know what they look like.
    Rafferty Thanks this.
  7. Rafferty
    26
    6
    Jan 26, 2008
    Iowa
    I would be interested. Sorry, I could find the warranty statement anywhere on the website. I came from the aftermarket supply side and I had a very tough time getting any supplier to pay for labor or any contingent damage. Not saying that Mahle/Clevite won't. If they will, that is a good warranty.
  8. grizzly
    599
    432
    Aug 27, 2008
    Layton, Ut
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I had this same question when inframing my ser 60. most shops told me aftermarket would work as they used them on their own trucks. the shop that did my inframe recommended oem. I went with oem. good thing I did, had small problem with coolant getting in oil. if I had insisted on aftermarket kit & had this problem after shop mgr recommended oem, he may of told me it's my problem for not getting what he recommended. so if I knew how to do an inframe & was doing it myself, I would use aftermarket (any familiar brand) but if having work done, I would use what they recommend.
  10. Dutch
    Dutch Light Load Member
    194
    58
    Commiefornia
    I say always go oem, theres a truck sitting at the back 40 at our shop that was inframed with a aftermarket kit, 3 broken liner flanges, and the company doesnt want to pay
  11. Rnz520
    Rnz520 Bobtail Member
    30
    8
    May 4, 2010
    Fredericksburg, VA, USA
    go OEM, its worth it. At the shop I work at if we do an aftermarket in-frame we are very cautios about warranty because the quality of the parts is so hit or miss.
