Info on buying a used reefer
Discussion in 'Refrigerated Trucking Forum' started by Wespipes, Jan 15, 2021.
  1. Wespipes
    Wespipes Road Train Member
    1,037
    1,815
    Jul 14, 2019
    So I own a flatbed and want to purchase a reefer and switch between the 2 when one gets slow. I know nothing about reefers. I drove local food service 48' tandem sliding reefer for 15 years as a company driver. They had thermo king on their trailers. Other then that idk what I'm looking for. What composite is best? How light should the trailer be? Is carrier or thermo better? What else should I look for? I'll mostly be running spot market. Of course I'm going to look for something low hours on it
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I would have the trailer inspected for metal fatigue(the floor, cross members & suspension) As far as the unit unless they have maintenance records(would look for one that does). I would make sure it is looked over very well. Carrier or Thermo king take your pick. Some companies won't load an older reefer trailer keep that in mind when purchasing one. All the best
    slow.rider, bzinger and Wespipes Thank this.
  4. Allow Me.
    10,642
    12,097
    May 28, 2009
    Rancho Mirage, Ca.
    Assuming tou want used, right ? Check crossmembers carefully. Also, if you can figure the previous owner, some co's beat the hell-o out of their equipment then sell it off. You don't want a unit that Coke or Pepsi or Budweiser had. Every load was grossing heavy. More wear and tear
    slow.rider, Wespipes and bzinger Thank this.
  5. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    @wichris
    check seals around rear doors..... during the day get in the trailer and shut the doors look for any light getting in..
  6. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Check the roof. I was so dumb 10 years ago. Trailer was good all around from the ground view. Good reefer unit, decent price. First good rain in OH and almost rejected load gave me some nervous moments.
    Aluminum skin on the roof was separated from crossmembers and was flopping developed long cracks along the roof. Roof skin must be glued tight to every cross member and be flat. Any floppy spots or bulging - refuse it.
  7. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    Borrow an infrared reader, run it down to zero and you'll know how water logged it is.
  8. abyliks
    abyliks Road Train Member
    3,742
    8,691
    May 2, 2010
    ludlow MA
    I would go with a tk or a carrier they seem to last better and are quieter, you can find a fairly decent used trailers for ~20k, wouldn’t go much older the. 8-10 years old either,
    Wespipes Thanks this.
  9. bad-luck
    bad-luck Road Train Member
    3,242
    5,937
    Nov 16, 2013
    Baltimore, Maryland
    Choosing between Thermo king and Carrier is just a preference. Important things to inspect are the floor, especially at the back where the doors are. Check the floor on the underside if the trailer, also check cross members under the trailer. Check for damage and bent cross members. Check the doors, make sure they close and seal properly. Inspect the seals around the door. Flat floors last longer then corrugated but are a little heavier.
    In my opinion, stay away from Wabash reefers, there floors are very weak. I would choose between a Great Dane and Utility only
  10. Knucklehead
    Knucklehead Road Train Member
    1,977
    24,664
    Jan 21, 2006
    Great Plains runs both. They're phasing out the TKs because the service shops tend to be a-holes more often than not.
    In case you're wondering, they sell their older trailers - 5 years and older, if I'm not mistaken.
  11. Peter_Bilt
    Peter_Bilt Light Load Member
    84
    54
    Feb 18, 2017
    You can buy a decent used trailer without a unit and then buy a brand new unit if that’s an option,...you can also buy a new trailer without a unit and buy a used unit as well if that’s your cup of joe. I say the first thing as every old unit I’ve used has needed new things within a year or two. I believe a compressor or engine is $5k in parts alone and then there is all the small stuff. A gearbox is $1k, the seal between the compressor and engine is about $900 to have someone else do it, I paid $500 on the road for sensor I couldn’t do because the Freon had to be taken out then put back in. Changed the alternator in parking lot one day, and have gone through 2 batteries. Life can be a real PITA with poorly maintained ones. Also, make sure you replace the belts and get a PM from the start and have them overlook everything. Trailer-wise, don’t mess up like me and get ripped off. Have it inspected by a pro. I’m still going through those woes but by the time I’m finished, I won’t need another trailer for at least a decade.
    bzinger Thanks this.
