Increase cooling system capacity
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by w9l, Aug 23, 2020.
  1. w9l
    w9l Medium Load Member
    316
    513
    Oct 12, 2013
    I caught just bits and pieces of a conversation B.Mallison and K. Rutherford were having with a caller that was having an overheating issue. They mentioned something about adding an extra tank, frame mounted that was to be plumbed into the rear of the head to increase the total liquid capacity of the cooling system. Did I understand that correctly? In my vocation when it is 90+ degrees is often when we push our trucks the hardest . Have to just lock fan on to maintain temp in safe range.
    truckdriver31 Thanks this.
  3. w9l
    316
    513
    Oct 12, 2013
    I might add that we have the biggest dimple tube radiators we can find. Pete379 deAcerted, and W900l with C mechanical. Both hold around 11 gal of coolant. When I was a kid drove my cousins 359xhd 3408pc alot and it always ran cool. Held about 17gal of coolant too.
    truckdriver31 and Rideandrepair Thank this.
  4. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    the new trucks have to run hotter. burns dpf filter soot. just drive the truck. bale if it burst into flames. that radio show will have you spending all your money.
    Snailexpress and Rideandrepair Thank this.
  5. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    The extra tank is simply just an air tank mounted on the frame behind the cab with lines circulating the coolant through the tank. Will cool about 10 degrees off of the temperature of the cooling system, If you need more just add two tanks and plumb them in series.
  6. xsetra
    xsetra Road Train Member
    5,111
    6,975
    Aug 21, 2011
    To add cooling capacity I
    thought about adding an extra bunk heater on the outside rear of cab.
    Just plumb into existing coolant lines for existing bunk heater and add a fuzed switched power feed.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Is there room to add another core?
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Old PC motors needed larger cooling systems vs direct injection because of the inefficiency.
  9. AModelCat
    158,799
    IMO if your temperatures are in check just run it. I wouldn't put the effort into fixing a problem that doesn't exist.
  10. 062
    062 Road Train Member
    6,208
    33,438
    Oct 20, 2013
    Another option is changing your coolant ratio.
  11. Rideandrepair
    17,333
    56,245
    Aug 8, 2015
    You probably caught the tail end of a sales pitch for waterless coolant. Something that sounds great, except Truck runs 20 degrees hotter, since water is the best coolant there is. KRs been peddling it for a while.
