Inactive to active vs new authority
Discussion in 'Ask An Owner Operator' started by kw600, Mar 12, 2013.
  1. kw600
    kw600 Road Train Member
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Hey fellas;
    Need some input on this situation; my father has his mc dot numbers and authority, but it has been inactive for over 6 years. We plan on doing our own thing soon and i know alot of brokers look at carriers numbers.
    Would it be better to activate my pops old numbers or for me to get a new set?
  3. Marlin46
    Marlin46 Medium Load Member
    504
    299
    Mar 17, 2010
    Atlanta, GA
    Re-activate the old ones for a couple of reasons, one of which you mentioned but I will list out a few in no particular order:
    1. Brokers / Shippers do look at the numbers ( if they take a quick glance ) which most do it will appear as though you have been in business for a lot longer than you have which shows stability from there view. If they take a long glance ( which a few do ) they will be able to see that it has been inactive for a while. At least on the ones that only take a short glance you will not have to put up with the must be in business for 6 months or 1 year type brokers.
    2. Insurance will be less or at least you shouldnt get the " new in business " surcharge by having a prior track record. You may have to request previous years loss runs which may or may not be a pain from 6 years ago but I am positive it can be done. The new in business surcharge can be around 20% and sometimes higher. If your father had a good number of claims then it may be better to go with new numbers but if there were very few claims it may work out better.
    3. If a DOT guy has to pick real quick between a high MC number or a low MC number which one do you think he is going to take a harder look at. If it were me and I had to quickly choose I would look at the high number. In no way do I think it is fair or right however it is just the way it is...kind of like brokers pushing the $1.50 / mile freight.
    These are just my thoughts on the subject and I am sure others will chime in and agree or disagree.
    kw600 and mcgoo422000 Thank this.
  4. kw600
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Thanks for your input.. I should add however that he never got around to using the numbers. He filed for the authority got everything needed and had to battle cancer so he couldnt work. He never even booke a load.
    That being said does it affect your last post?
  5. Marlin46
    504
    299
    Mar 17, 2010
    Atlanta, GA
    I would still go with the old ones...maybe you do not get the advantage of No.2 above however the other two would still apply and more than likely you would avoid the FMCSA "New Entry Audit" - which isnt a huge deal it is just one less thing to deal with which counts for a lot in this business.
  6. kw600
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Would we be able to change the name of the business or is it too much of a hastle?
  7. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    You will need to pay a $80 reinstatement fee to reactivate the old number. New authority costs $300 and you will need to wait a few weeks to get your authority back. You can get a reinstatement letter on the old number in a few days. You can change the name, but I believe there is a fee to make the change, but I don't think it is very much. I would probably go with the older number so that I could start a little faster and for less cost. You will still need insurance to be active prior to your authority being reinstated or if you decide to get your own MC number. Good luck.
  8. kw600
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Thanks G. I guess we lucked out having an "old" set of numbers. Time will tell!
  9. Regional
    Regional Light Load Member
    240
    45
    Apr 4, 2020
