In truck sleeping vs hotel
Discussion in 'Expediter and Hot Shot Trucking Forum' started by AndrewW, Aug 14, 2020.
  1. AndrewW
    AndrewW Bobtail Member
    23
    8
    May 8, 2020
    My assumption finally came true and I received my lay off date. It doesn’t surprise me. I was able to read between the lines. The only hold up was that our union was in the middle of a contract agreement with the city and they couldn’t get out of it. So, I received a lay off notice for October of 2021 when the contract ends. When that happens, I’ll be leaving this god awful state (California) and hope to start a hotshot business. You guys have been super helpful so far so maybe you’ll allow me to pick your brain some more.
    How many of you sleep in the truck as opposed to hotels? If sleeping in the truck, do you idle for air/heat or use some other system? Sleeping in the truck seems like it would be real old, real fast. But, hotels can lack parking and are expensive. What have you done? What system works best for you? How has your experience been idling the truck for the night/day?
    thanks for the time.
    Coffey Thanks this.
  3. 24kHotshot
    24kHotshot Heavy Load Member
    801
    874
    Feb 19, 2019
    New York
    I sleep in my truck. I limit my idling to about half an hour at most at a time to cool/heat the cab. These new trucks hate idling. I had a reset in jacksonville last summer. Was about 100 degrees and I idled a lot. After about 5 hours I got the check engine light and the def system light and the truck had less than 10,000 miles on it. That was the last time I idled more than 30 mins. Luckily the lights went away after cruising at highway speeds for about 30 minutes.
    I've been looking for an AC that would run on a 2k watt generator and won't take up so much space for months and no luck so far. I have a battery operated 8 inch fan that can run all night on a charge now and I make do. 30 minutes before I go to sleep I turn on the AC to full blast for 30 minutes and then run the fan all night.
    I don't want to find or pay for a hotel every night that has parking for a semi.
    If I had to do it all over again I'd shell out for a single axle semi sleeper with an APU.
    My current setup:[​IMG]
  4. Lite bug
    Lite bug Road Train Member
    1,391
    28,694
    May 3, 2014
    Columbus Ohio
    Yelp that is the setup. I carried a 3500 watt gen. with a portable A/C and did not idle. A few times in the winter idle all night when in the single digits, of course older 7.3 powerstroke without new junk. I now use Points with Super 8 and get a discount when I stay out. Used the fuel points for showers. Staying in the truck gets old fast. After a while human smell lingers.
    singlescrewshaker and 24kHotshot Thank this.
  5. Wasted Thyme
    7,729
    38,304
    Jan 27, 2020
    GOAT watching
    You might want to consider a mini split.
    singlescrewshaker Thanks this.
  6. AndrewW
    23
    8
    May 8, 2020
    How much you think you pay for a room a night? What’s the average shower cost at a truck stop? Do a lot of truck stops charge to sleep there? If so, a hotel wouldn’t be that much more expensive.
  7. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,568
    Dec 30, 2017
    Coal Town
    Showers are like $12. Some TAs are all pay only and they charge like $15 per spot. A decent hotel room is like $55.
    singlescrewshaker and Lite bug Thank this.
  8. 24kHotshot
    801
    874
    Feb 19, 2019
    New York
    I use pilots most of the time. Parking is free, every 50 gallon fuel up is a free shower credit. Also get 1-2 free drinks a week through the app among other discounts.
  9. Lite bug
    1,391
    28,694
    May 3, 2014
    Columbus Ohio
    Now if you are leaving California and starting a hot shot business best to relocate to area that has the most opportunities. This will be up for debate as each region has pros and cons. I read something stating “ in order to be successful in the hotshot business stay north of Hot Lanta east of the Big Muddy and stay out of the Northeast “ there is a lot of truth to that statement as this is where a lot of manufacturing takes place. Wherever you to go it is important to be near outbound freight.
  10. Brandonpdx
    Brandonpdx Road Train Member
    4,184
    3,972
    Dec 27, 2007
    Elkhart, IN
    Most hotshot guys sleep in their truck I’d guess. Hotels are a pain in the butt and expensive.
  11. AndrewW
    23
    8
    May 8, 2020
    We’re looking at Texas. I have read that both the DFW and Houston area are good outbound freight areas. Plus the general cost of living is better. Coming from CA, the cost of living is going to be substantially better almost anywhere we go.
    Lite bug and singlescrewshaker Thank this.
