in need of a/c wiring diagram w900
Discussion in 'Kenworth Forum' started by dc730, Oct 20, 2016.
  1. dc730
    dc730 Light Load Member
    184
    118
    Jun 10, 2016
    anyone have a wiring diagram for the w900 ? i have a 2013 but i would have to guess any from the newer style 2007 and newer would be the same? i recently lost power the the a.c compressor clutch . the pressure switches are good. thank you
  3. AModelCat
    154,240
    Is there still a refrigerant charge in the A/C system? Also a lot of newer vehicles lockout the A/C below a set ambient temperature and only allow the compressor to cycle occaisionally for defrost.
  4. dc730
    184
    118
    Jun 10, 2016
    yes, and it was 90* yesterday ive been electrical issues. the pressure switch up by the a/c compressure had loose connection that kept tripping the engine fan non stop fixed that was good for 1000 or so miles now the ac not working.
  5. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Find the a/c relay, then key on eng off put your finger on the relay and with other hand push the a/c dash switch, if the relay clicks this shows the ground side switching works, now check to see if the a/c compressor clutch locks up, if not wiggle some wiring, it may start engaging if you find a poor connection.
    I will see if I can upload a wiring diagram
  6. kwcam
    193
    145
    Dec 29, 2012
    at the shop
    hope this works
