In-cab scales...
Discussion in 'Ask An Owner Operator' started by Dumptrailer, Jul 15, 2015.
  1. Dumptrailer
    Dumptrailer Bobtail Member
    11
    May 10, 2015
    Hello everyone I'm new here and new to trucking. Currently pulling dump trailer locally in western mass. I'm planning on buying my own tractor and dump trailer in the next year or 2 and it seems that not going over weight is a big obstacle in the dump truck industry. I see a few companies that make in cab scaled that convert air pressure to actually weight and wondering how well
    They work and how hard they are to get installed. Should I make sure that my truck has a suspension gauge already so it has the lines behind the dash already? And input would be helpful. Thanks, Matt.
  3. BigCam9670
    BigCam9670 Medium Load Member
    417
    4,585
    Jun 12, 2012
    Hudson, NY
    You need an air suspension load gauge. It is plumbed in to the airbag lines. There are plenty of companies that will sell you a gauge or a "kit", which most likely is just a roll of 1/4" plastic airline, some fittings and the gauge itself. My pete 379 has one from the factory, mounted nicely in the dash. Who are you working for in W. Mass? We are out of the Albany, NY area but we run mass a few times a week.
  4. Dumptrailer
    11
    May 10, 2015
    So does your gauge give you actually weight in lbs or is it just psi? I'm with a small company called white wolf trucking in Washington mass. I don't think we run in NY at all.
  5. BigCam9670
    417
    4,585
    Jun 12, 2012
    Hudson, NY
    It is just in PSI. You may have to weigh on a scale to get a baseline correspondence between PSI/lbs. Mine reads 65psi when I am at 34k lbs on my drives. Pete Air Trac suspension
    Dumptrailer Thanks this.
  6. Dumptrailer
    11
    May 10, 2015
    Ok I gotcha
  7. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    Right Weight makes a scale gauge with weight in pounds. It's adjustable. Get a max load, scale it, adjust gauge.
  8. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    We have them on a couple trailers. They work good.
  9. glitterglue
    glitterglue Light Load Member
    53
    45
    Jan 22, 2011
    Adair Village, OR
    How accurate are Right Weight (http://www.rwls.com/) scales in real-life use? I see on their website that they are accurate to 300#'s. Not having used in-cab scales, is that good, bad, normal?
    My concern is that if you're right at GVW, a 300# error, on multiple axles, is going to cost you...
  10. ipogsd
    977
    515
    Jun 13, 2012
    I have one on my drives. I use it to balance weigh. If I'm really close to max I still use a CAT scale.
    glitterglue Thanks this.
  11. shovel98
    shovel98 Light Load Member
    251
    241
    Jan 15, 2011
    mn
    Have two right weigh guages in truck just tee it of my suspension gauge I ran one for my trailer which I put in cab also ran line all the way up from trailer bags and used a air coupler to disconnect when switching trailers. Weigh it with all axles down at max weight and it will be real close. Used it on both my spread flat and my closed tadem reefer was great with reefer sliding and watching weight from in cab. Right weight isn't that expensive thinking it was right around 225 for both if rember right been awhile. Used a electronic one on a Triaxle trailer hard to get set right when first using it when trailer was new would never get that one again.
