Importing a non HGV to the USA, license question plus more
Discussion in 'Questions To Truckers From The General Public' started by Amyy, Sep 1, 2009.
  1. Amyy
    Amyy Bobtail Member
    6
    4
    Sep 1, 2009
    Florida
    Sorry if this doesn't make sense, I'm originally from England (the country, not the trucking company!!) and I'm a little confused when it comes to which license is required over here. I'm looking for some help answering questions regarding driving a non-HGV in the USA (sorry not sure what Americans call it, HGV = heavy goods vehicle)
    I'm in the horse business. Most people in the UK don't use a truck and trailer to transport horses, they use something called a horsebox. Horseboxes have some advantages over a trailer, the main one being you can go through the back of the cab straight into where the horses are. This is great because as long as you have someone driving with you, they can check on the horses while you are still driving.
    Here are some examples of what they look like (the one I want will be older and cheaper lol, this is just an example)
    http://www.horseboxworld.com/horseboxes-for-sale/horseboxes-for-sale.asp?offset=60
    I don't know of anyone who makes them in this country, do you? So I am thinking of importing one from the UK to the USA.
    Possible problems:
    You can drive a horsebox in the UK on a regular license as long as it is a non-HGV (7.5 tonnes or under) Will I be able to do this in the USA?
    The steering will be on the right side, do you think I will find some difficulties with this?
    maintenance/mechanical problems. Any problems for mechanics with the steering on the other side? I may have some trouble with getting parts etc. Most commonly, horseboxes are ford cargo/iveco and leyland daf. But there are some MAN, scania(HGV only I think), mercedes, volvo. Are any of these made over here?
    Thanks for any help!
  3. Irishtrucker
    Irishtrucker Medium Load Member
    489
    193
    Jul 20, 2009
    Sacramento CA
    Hey there
    From Belfast myself but now in cali.
    As far as driving a RHD on the right, my experience is from driving RHD lorries on the continent and although it takes a little getting used to shouldn't be impossible to do.
    I have never seen a horse box truck like home here but that doesn't mean they don't exist. Mostly see horse trailers on pick ups. The problem i forsee with importing a truck is getting parts and a mechanic to work on it. Might be easier to do as the romans do.
  4. KO1927
    KO1927 Medium Load Member
    569
    263
    May 19, 2009
    NH
    Put "toy hauler camper" into a search engine. They seem to be similar to the English Horsebox, but made for hauling dirt-bikes, ATV's etc. They are available in trailer or "motorhome" configurations.
    Depending on the chassis that a Ford horsebox is made on, parts availability might be okay since Ford is an american company.
    Your most economical option is a 3/4 or 1 ton rated pickup and the horse trailer.
    These models are as follows:
    Ford: F-250, F-350 (3/4 & 1 ton respectively)
    Chevrolet: 2500, 3500
    Dodge: 2500, 3500
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    There are straight trucks in the US that are built to haul horses, but they probably do not have access from the cab into the stall area. Any vehicle you import into the US must pass all the DOT standards for that style/type vehicle. That may include safety features, lighting and engine emissions. Getting parts for European models that are not similar to ones sold in the US will be very difficult.
  6. Redtires019
    Redtires019 Bobtail Member
    11
    Sep 3, 2009
    Dothan Alabama
    As for the driving license, The Commercial driving license rules state that once the vehicle gross weight is over 26,000 lb (11793 kg) or the vehicle is pulling a trailer with a gross vehicle weight over 10,000lb (4536 kg), then you would need a CDL. At 7500 kg ( or 16,534 lb) it is under the weight requirement so I think a normal Driving License (class D) should be all that is required
    As for the tagging or registering of the vehicle, the requirements can vary by state. It will also vary depending on whether you haul just your own horses, or hire out for hauling other peoples horses. You might want to contact the state you are moving to and inquire with them.
    Another thing with the vehicle is the U.S. can be a sticular for it meeting their requirements, esp emissions related stuff. I have known more then one person in the military that has exported their vehicle, had work done one it either here or abroad and had something removed from it and find out later when they are redeployed home the vehicle can not be brought back unless it is restored. I have also had an Uncle in the 80's who bought a SAAB while in Germany and he could not bring it into the States unless it met the E.P.A mandates for that year. He would us selling it and buying one here, it was cheaper than trying to retrofit a catalitic converter, smog pump, ect.
