Ignition toggle and starter button instead of key
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gumper, Mar 1, 2018.
  1. Gumper
    Gumper Road Train Member
    1,554
    3,628
    Jan 7, 2018
    Butte, MT
    I’m thinking of bypassing my worn out ignition switch, and putting the power to a toggle switch with a momentary starter button. Also have a switch for the accessory. There’s 3 auxiliary switches on a factory panel that aren’t being used. How’s this for any idea? Better than paying Kenworth a small fortune for a new ignition cylinder, and a decent anti theft setup. Does anyone have a wiring diagram for a ‘97 W900?
  3. wore out
    wore out Numbered Classic
    15,340
    185,252
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    A test light would tell you all you need to know to accomplish that
  4. Tug Toy
    Tug Toy Road Train Member
    6,932
    72,426
    Jul 4, 2015
    Corn field
    You better start getting used to spending money on stuff you need for that thing. A ignition cylinder is nothing in the scope of what’s coming at you. I would never buy a used truck that the ignition was all hacked up. That’s a fire waiting to happen where you will be sleeping. Especially if you think you need a working diagram to do it?
    But it’s your truck, do as you please?
    mslashbar, swaan and wore out Thank this.
  5. Gumper
    1,554
    3,628
    Jan 7, 2018
    Butte, MT
    I can only imagine how many times in 20 years the ignition has been turned in this truck. Things wear out, and it’s too late to turn back now.
    I guess I missed out on the truck that doesn’t ever have problems. Can you go ahead and show me that one?
  6. mtoo
    mtoo Road Train Member
    1,928
    4,427
    Jan 15, 2011
    Retired on bended knee
    Drop it off at a dealership to get some work done on it will be a nightmare. Mechanic will be trying to figure out how to start it for 30 minutes, just trying to run it into the shop.
    My B model Cat had a factory Kysor low oil pressure-high water temp shut down system. It had a factory override toggle to start the engine. Push the toggle until oil pressure built.
    As years went by fewer and fewer Pete/Cat mechanics were familiar with the system, I would get a call (we can't get your truck started)
    I ended up taking a rubber band and holding the toggle in the override position every time I dropped the truck off where a mechanic had to start it.
    Oxbow, mslashbar and wore out Thank this.
  7. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Every now and then we have a mechanical engine get dropped off at our shop to work on. Poor young guys have no idea of a murphy gauge or a manual pull shut off. "I parked in the yard and the jakes stayed on and killed the engine??
    Oxbow and Goodysnap Thank this.
  8. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    I would buy ignition cylinder and be done with it and I am seriously a cheap #######.
    Don’t know why they ever strayed away from having starter switch under throttle pedal or on the dash
    Oxbow and AModelCat Thank this.
  9. Gumper
    1,554
    3,628
    Jan 7, 2018
    Butte, MT
    When I get the truck back from the clutch job I’ll dig into it and make the decision which way to go.
  10. Jazz1
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
