IFTA Taxes and Which Turn Pikes and Toll Roads are exempt
Discussion in 'Trucker Taxes and Truck Financing' started by redoctober83, Jan 18, 2017.
  1. redoctober83
    redoctober83 Road Train Member
    2,407
    2,291
    Sep 10, 2013
    Seattle, wa
    I know I have read on here this question many times. While looking some stuff up on the IFTA website I came across the section about exemptions by state and roads. Come to find out turnpikes in NY, PA, OK, KS, IL and all the other states with turnpikes ARE NOT exempt from IFTA. The only state that has an exemption is MA. Just thought I would pass this on and the resources the IFTA website offers.
    PE_T, KB3MMX, bbechtel16 and 2 others Thank this.
  3. MysticHZ
    MysticHZ Road Train Member
    5,875
    5,678
    May 28, 2010
    NY reimburses for the miles on the toll ways.
    roshea Thanks this.
  4. redoctober83
    2,407
    2,291
    Sep 10, 2013
    Seattle, wa
    You talking about when you submit your miles through Oscar or there online system if you have a hut sticker? That's completely different from ifta. I don't remember that question when I logged into my ny account, though I didn't have any miles in NY last quarter either.
    wis bang, PE_T and Dieselboss Thank this.
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    I think you would still report them, but list them under Toll Roads.
    http://www.ooida.com/EducationTools/Info/IFTA-info.asp
    TOTAL TAXABLE MILES - Enter the total taxable miles in each jurisdiction minus fuel trip permit miles. Fuel trip permit miles are not considered taxable miles in any jurisdiction. Toll miles and off-highway miles are not taxable mile in some jurisdictions. Contact each jurisdiction for information on these exceptions. If you forget to write down taxable miles, total miles will be used as taxable miles. NOTE: Total taxable miles cannot be greater than total miles
    https://www.iftaboss.com/ifta-questions/exemptions/
  6. redoctober83
    2,407
    2,291
    Sep 10, 2013
    Seattle, wa
    The only toll roads that are not taxable according to ifta website which is the most up to date is the turnpike in Massachusetts.
    If you follow the links I posted in my op you'll see the table from ifta broken down by type of road and each state.
    PE_T Thanks this.
  7. redoctober83
    2,407
    2,291
    Sep 10, 2013
    Seattle, wa
    You are correct, you report all miles driven in each state and then it asks which for total taxable miles and most of the posts I've read on here in the past have said that toll roads and turnpikes you don't count since you paid a toll on it. Ifta says otherwise and wanted to make sure people knew.
    slow.rider and PE_T Thank this.
  8. Mark Kling
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    I agree, report all miles, but broken down via Toll/Non-Toll for taxes.
  9. redoctober83
    2,407
    2,291
    Sep 10, 2013
    Seattle, wa
    There's no place to break it down for toll or non-toll unless you're talking about actual taxes for the IRS
  10. Dieselboss
    Dieselboss Technology Contributor
    1,648
    1,365
    Feb 19, 2009
    DieselBoss.com
    Sort of. (please forgive, those who know IFTA inside-and-out, for the following. I hope that it may help many others whose eyeballs bleed when it comes to what IFTA is.)
    Even though IFTA was created to be a "uniform and simple" way for the states and provinces to collect an additional heavy commercial vehicle fuel taxation revenue stream, it is far from uniform or simple. Yes, the basic concept generally is not to hard to understand. But it is the exemptions that are complex and painful to keep straight for sure.
    Here is IFTA in the most simple sense: You drive a vehicle over 26,000 pounds on my state roads and my state wants to collect some tax from you for the additional wear. (there are other terms, but I am simplifying remember)
    It is calculated by charging you extra at the pump (except in Oregon) and then you must document all of this "driving and buying of fuel" each quarter to your home state which issued your IFTA sticker. The problem is that YOU don't always BUY FUEL IN MY STATE. So you drove on my roads, but you didn't pay my tax at my pump! In other states you bought LOTS of fuel but didn't drive a lot of your miles there. You overpaid me at the pump. Based on your truck MPG, I can figure out how much you owe my state per mile that you DID drive here. And I may owe you a refund, or you may owe me more. Your state will then pay or collect from the others as needed.
    And to make it more complicated, some states want an additional "heavy use" tax on top of IFTA. (New York, New Mexico, Oregon, Kentucky.)
    To figure out your MPG and to document to all of these states and provinces, you would (and do) have to document every mile driven and every gallon bought that went into the propulsion tank to drive those miles. (even the exempt miles) Once you know the MPG, and the miles, and the IFTA rate of that state - you know whether you owe them more than you already paid at the pump, or whether they owe you. You may know your MPG through other methods, but THEY don't. Note that if you have more than one truck under your authority, the IFTA MPG is calculated as a "fleet average" when paying.
    So, to the original post statement - turnpikes and toll roads are usually NOT exempt from IFTA, which is what he stated correctly. BUT, there is an "exception" for the Mass Turnpike. And there are also several states/provinces/territories that are exempt from IFTA. You still need to document those miles, but you put them down as "Non-IFTA" miles (or kilometers if you are Canadian based.) In the case mentioned with Massachusetts, you need to file their form ST-10 annually if you do list their turnpike miles as Non-IFTA miles during the quarterly IFTA filings. (you can read the Mass instruction here if you like)
    There are other exemptions. They list them as either "Distance, Vehicle, or Fuel" type of exemptions. The table is large and complicated here (https://www.iftach.org/exempt/view/general2017n.php) And they are different for each jurisdiction. If you suffer from insomnia, click through all of them to see which you may qualify for. Most drivers do not qualify because they are uncommon and the government counts on that. The most common one I see pertains to oil rig delivery drivers who tend to do hundreds or thousands of miles on non-government roads in a quarter.
    So, with all that said, you do want to sometimes know what tolls, turnpikes, thruways you drove because there are state HUT taxes (like the New York Thruway HUT miles exemption, not for IFTA) and Mass Turnpike exemption (IFTA.) Plus you don't want to forget those additional (on top of IFTA) taxing states like NY, NM, KY forms to file and pay. But for IFTA, they don't break out "toll verses non-toll" normally with the exception of the Mass Turnpike. Rather, they look at it a "Taxable or Non-IFTA" miles via the exceptions link posted here.
    Reason for edit: spelling
    Mattflat362, PE_T, BoxCarKidd and 10 others Thank this.
  11. trailgrl
    trailgrl Bobtail Member
    In MA if don't claim the toll miles on IFTA then MUST report USE tax to that state. If you ever get an IFTA audit they can check to see if this was paid and if not then will be paid on IFTA.
