if the clutch goes out....
Discussion in 'Questions From New Drivers' started by Mud Dog, Jan 8, 2012.
  1. Mud Dog
    Mud Dog Tattooed & Insane - Forum Sparkler
    695
    576
    Dec 8, 2009
    Devil's Land, kentucky
    This happened to me on the way home Saturday and got me thinking. This is a question for new drivers and will hopefully help them out. And yes I know how to drive w/o a clutch :biggrin_2554:
    If the clutch goes out do you know how to safely drive to a safe place or for repair? What if you have to stop?
    thehornet Thanks this.
  3. cuzzin it
    cuzzin it Road Train Member
    3,399
    7,783
    Jan 19, 2008
    Berea, KY
    you turn the motor off, put it in gear and turn back on when you are ready to move
  4. Lokix
    Lokix Light Load Member
    107
    25
    Mar 20, 2006
    NW Ohio
    I drove my car for about a month w/out a clutch. Different from a truck, I'm sure, but it was still pretty hairy! Taught me to "float" in my car, anyhow.
  5. Bigrigin
    Bigrigin Light Load Member
    75
    25
    Illinois
    Most of the newer trucks won't start in gear you have too push the cluch in, and if the cluch is out it most likely won't start once you shut it down, safety thing
  6. thehornet
    thehornet Medium Load Member
    333
    75
    Dec 26, 2011
    3 doors down
    Mud dog, hoping you come back on and let us know, cuz honestly never thought about that and would not have a clue as to what to do. Although we always had to double clutch in school, one instructor showed how you do not even have to use the clutch., but also advised us until we get a ton of experience, to not even try it..
    What's the answer Mud dog? Now I have a need to know..
    Thanks
  7. haulhand
    haulhand Road Train Member
    I've run brand new iron for a long time and never had one with a clutch disconnect but I've ran nothing but paccar in my fleet. The correct answer is shut it off when you stop put it in gear and start the motor when your ready to go. If a clutch is purely mechanical which it is and has no power going to it how does a computer kno that it has gone out? Answer it doesn't. If you do have a clutch disconnect then just push the pedal to the floor and start it in gear.
    - Sent from my iPhone using Tapatalk
  8. EZ Money
    EZ Money Road Train Member
    My 2011 will start in gear with the clutch pedal pushed in.
    I drove one from Memphis to NC with no clutch.
    Not too bad except for going through the chicken house...
    If you can float gears you can get it home..
  9. jgremlin
    jgremlin Heavy Load Member
    867
    497
    Apr 21, 2010
    SW Michigan
    Ok this is an area I know very little about. My only exposure to a bad clutch in a truck was a second hand report from a guy I worked with who happened to be leased on where I was working as an o/o.
    We did more or less local runs of steel coils at that company. He said he was loaded near max gross and was 3/4 of the way to the delivery when he got to some hills and the truck wouldn't stay in any gear above 3rd. He said 1st 2nd and 3rd were ok. But if he shifted into a higher gear, it would pop out. He told me he put the 4-ways on and limped on the shoulder at 10mph the rest of the way to the receiver. Once he made the delivery and was empty, the truck would stay in gear again so he was able to get it home. He took it to his shop and they put a new clutch in it which cured the problem.
    So my limited understanding is that the first sign of clutch failure is the truck popping itself out of higher gears when loaded heavy. Are there other clutch failure modes?
  10. haulhand
    That's strange every time I've lost a clutch it just went out with not much warning of course I use my clutch very little anyway.
  11. J Man
    J Man Medium Load Member
    304
    195
    Dec 31, 2011
    Middle of nowhere
    Had a clutch go out on a motorcycle once, that was fun limping that home. The clutch disconnect was just a circuit on the clutch mechanism itself, so if it had stopped I could have started it in gear, but it was a big heavy bike and would not have liked it. As it was I was able to get off the freeway and onto the back roads and just limp along.
