I hope these are not dumb questions. When a company has trucks without APU's and have an auto start/stop feature when idling, I am wondering exactly what that means? Does it work just like it says? Does the truck's diesel engine start up and turn off by itself intermittently for a predetermined duration? If so, is the idle time allowed by this feature to run the A/C adequate to keep one cool in hot humid climates while in the sleeper? Or does the truck just idle for a period of time just once, then shut off for good? Thanks.
Idling Auto Start/Stop Questions
Discussion in 'Questions From New Drivers' started by texasbigbird54, Jul 14, 2013.
Page 1 of 3
All computer controlled engines can be shut down with a timer, certain engines can be equipped with a control to start and stop the engines as needed to maintain temperature, coolant or cab, and battery voltage.
IKON is the Cummins version, i think, and OPTI-IDLE is the version for Detroit, I don't know if Volvo and Mack have anything, or if Caterpillar did, and the older, non ECM controlled engines had no way to do this.texasbigbird54 Thanks this. -
I went to the neighbors today.
He's got an 06 pete with an ISX. It was running when I got there.
Went inside, talked a bit, came out so he could change the oil. It had shut down.
He's an O/O and has owned it for over 5 years. He still has his auto-shutdown in the ECM enabled. Never said a word about it....
I know on my Detroit S60, I can set it for either thing. Shuts down after X time or I can have it keep track of temp and start/stop within the parameters.
I just have it set to run non-stop instead.texasbigbird54 Thanks this. -
Heres what you do.Bump the cruise switch and it will remain idling.My trk does it,it shuts off like in 5 minutes.So I hit the cruise an it idles high then stays on.You can hit cruise high then tap it again to lower the cruise and it will still remain idling.
It's similar to the ac in your home. You set your desired temp. Once the truck reaches the desired temp, let's say 72 degrees, the truck shuts off. When it senses a 4 degree variance between desired temp and actual temp the truck will start and run until it hits 72 again. It will do this as long as you have the opti idle engaged.
USA Truck had that on their trucks, and it did help save fuel but one time it had me believing I had a ghost. It was set to run on temp setting and it was -20 out side and I ended up sweating cause it never shut back down. I got up turn the key off and laid back down. No sooner my head hit my pillow it started back up again I almost ran out of the truck. (Key was in the Off Position)
WesternPlains and texasbigbird54 Thank this. -
OR when you physicly turn the key to turn it on. My truck will cycle through on off on off every so often even with no key
The Volvo's auto idling when you are on cruise and flat land also on grades. It will then shift to the gear needed for the road.
Page 1 of 3
