I Want to install a boost gauge and EGT gauge
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SimD, Apr 27, 2013.
  1. SimD
    SimD Light Load Member
    148
    30
    Dec 23, 2012
    dallas, tx
    I have a bone stock c15 acert, what kind of boost gauge do you guys recommend 30psi max or 60psi max, Where should I plug the boost gauge in on the engine, and can the gauge be like car turbo boost gauge? Any website to order good boost gauge from?
    And now, where should I plug in the EGT gauge on the exhaust?
  3. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    For an Acert you will need atleast a 60psi gauge. Look on the driver side of the engine on the head to the right of the intake horn you'll find a pipe plug, just pull that out and install the fitting for your gauge. You can use ANY gauge rated for air
    You may need a new turbo outlet pipe or have a bung welded on yours if it doesn't have one. Either that or you would have to drill and tap the manifold to install it there. Ideally on truck they are just installed in the exhaust right after the turbo
    cetanediesel and SimD Thank this.
  4. SimD
    148
    30
    Dec 23, 2012
    dallas, tx
    Thanks a lot
  5. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
