I want to haul cars...Do I Need a CDL ?
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by BlueThunderr, Nov 20, 2013.
  1. BlueThunderr
    BlueThunderr Medium Load Member
    495
    276
    Sep 11, 2012
    I'm thinking about starting a business to haul cars....This would be done with a pick up truck and a trailer behind...perhaps one that can hold 3 cars....
    I am a little confused on 26001# weight thing....
    Would that 26001# be the total weight of the pick up truck, trailer, and cars behind hauled ? Or just the trailer and the cars being hauled ? Or maybe just the weight of the cars ?
    Thanks in advance....It seems confusing.
  3. BlueThunderr
    495
    276
    Sep 11, 2012
    Mods - I just realized there is a car hauling section here if you could please move this thread there....thank you.
    d o g Thanks this.
  4. peter_x
    peter_x Light Load Member
    89
    51
    Aug 24, 2013
    Your pickup truck isn't a cdl vehicle. If your gross combined weight is no more than 26,000, I don't believe you need a cdl even if you are towing more than 10,000.
  5. Pullin2
    Pullin2 Crusty Canuck
    1,991
    3,611
    Nov 5, 2011
    Whoville Pub, Long Island
    Take an hour or so and research this sub-forum - lots and then some of your questions are answered ......... luck
    truckon Thanks this.
  6. BlueThunderr
    495
    276
    Sep 11, 2012
    I have...I read the forum for about 3 hours last night.
  7. truckman29801
    truckman29801 Medium Load Member
    469
    109
    Mar 10, 2013
    SC
    If your trailer is over 10,000 then you need your cdl. Because then its considered a class A vehicle. I know one of the guys on here i speak to regulary is from NY and he had to get his cdl with his wedge and dually. If you dont agree go ahead, call your local Dmv and ask this simple question....."my trailer is over 10k......do i need a cdl? And they will say yes. You can take the test in a dually and a car trailer that has a trailer gvw over 10k but you will recieve a E and O restriction, (restrictions are universal now) automatic restriction- if you took the test in an auto, and an "Except tractor trailer" which means you cant drive a truck up to it thats designed to carry over 26k in the door or ID plate that has fifthwheel articulation, ie. A semi tractor. Now if you can get a trailer that the gvw says 9,999 then you dont need one but for some reason i highly doubt you'd be at a legal weight with 3 cars then and the dot would eat you alive.
  8. truckman29801
    469
    109
    Mar 10, 2013
    SC
    Theres also multiple topics on here about it. Good luck
  9. SemperFiServices
    SemperFiServices Medium Load Member
    379
    230
    Jan 29, 2013
    Indianapolis, IN
    Some guys run a truck, trailer, and 3 lightweight cars and somehow manage to stay under 26k, but I personally like the ability to pick ANY 3 vehicles to put on my trailer w/o worrying about finding a scale before I hit the DOT scales. Just get your CDL in a dually and wedge at a minimum and you don't have to worry about keeping light.
    truckman29801 Thanks this.
  10. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    You may not necessarily need a CDL with your trailer. New York states rule reads "
    • A trailer with a GVWR of more than 10,000 pounds if the gross combination weight rating is 26,001 pounds or more". So if your 26k or under you should be ok. I would get it anyways.
  11. peter_x
    89
    51
    Aug 24, 2013
    Exactly. I don't think he needs a cdl at all, at least in NY. If he is using an F-350 with a gvwr of 13500(?), then he could use a trailer with a gvwr up to 12500.
