I ran out of fuel
Discussion in 'Questions From New Drivers' started by Josh_B, Aug 17, 2015.
  1. Josh_B
    Josh_B Bobtail Member
    44
    17
    Jun 30, 2015
    ok first, I admit that I am a retard. Now I just want to know how to fix it.
    i have a 2006 kenworth T2000 with a Cat engine. it was on less than 1/4 of a tank, but i decided to wait and fuel when I heading out. I parked but let the engine idle. it started to shutter and i turned it off right away. but now Im sitting here 40 yards from the pump and it wont start back up. I put 5 gallons in from a gas can hoping that would help, but no luck. please help.
  3. Josh_B
    44
    17
    Jun 30, 2015
    read tar did one is apearently a curse word
    Cottonmouth85 Thanks this.
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    If you cannot find the primer on the engine, go get some starting fluid from the store or where ever you are at. Spray a little in the air filter and try to start it.
    Josh_B Thanks this.
  5. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    ^^^ Do as Bakerman suggests, also look at the fuel filter. If it's bone dry, unscrew top cap and pour some diesel into it as well.
  6. lots of character
    lots of character Road Train Member
    1,031
    1,814
    Aug 12, 2015
  7. If you have a c-15. Filter is driverside close to firewall. Carefully I repeat slowely unscrew and fill with diesel from gas can. Screw back on, wipe exceeds off filter to see if its leaking. Turn her over till she starts. You will need a filter wrench just saying
    Straight Stacks and TruckDuo Thank this.
  8. passingthru69
    Use the primer pump and crack open the rear injector line. Keep pumping until you see fuel coming out of the line. Tighten the fitting and tight the hand pump and fire her up
  9. passingthru69
    You sucked air into the system... Cats hate that.. Lost prime..
  10. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    The word you used did not pass the word filter so you found a different way to spell it to make sure everyone saw it? You have not quite grasped the purpose or "mission statement" of the word filter, have you?
    Mikeeee
  11. Pmracing
    6,354
    3,178
    Jan 28, 2011
    I would have suggested diesel. But that is just me...
    Mikeeee
