I need new tires for my trailer, what do you recommend?
Discussion in 'Ask An Owner Operator' started by Beaver9, Nov 22, 2021.
  1. Beaver9
    Beaver9 Heavy Load Member
    966
    1,183
    Jun 15, 2020
    Which brand do you recommend? I need to change all 8. What do you have now?
    Where do you get them from?
    Thank you
  3. Tug Toy
    Tug Toy Road Train Member
    6,932
    72,427
    Jul 4, 2015
    Corn field
    What kind of trailer and budget?
  4. REO6205
    REO6205 Road Train Member
    13,172
    60,483
    Feb 15, 2014
    California.
    What kind of trailer? What kind of hauling do you do?
    Lonesome and Midwest Trucker Thank this.
  5. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    I bought cooper LHT for my van fresh alignment and shocks yearly. Centramatics and generally get great life out of them. Rotate around 80k miles
    Last set 175k
    Beaver9 Thanks this.
  6. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    Availability might be what makes your decision for you right now. Shortages and price jacking are a real pain currently.
    Evil_E, Beaver9, Oxbow and 1 other person Thank this.
  7. JerzyG
    JerzyG Light Load Member
    91
    260
    May 23, 2020
    For tandems I'd recommend Bridgestone R123, as for spread I'd go with the General RA. They're not the cheapest option, but I've had the best use out of them.
  8. shooter19802003
    5,654
    42,106
    Feb 8, 2010
    I have generals on my spread flat and they have really held up well. Better than I could have hoped actually.
    ProfessionalNoticer, Beaver9 and Oxbow Thank this.
  9. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I run a 53’ spread with slide lift and dump so I usually can run with only the rear set on the ground
    I run Michelin on everything
    XZE2 on the trailer and usually will pull that rear set at about 200k
    Put new on the front and rotate those back for another 100k depending how they look
    Used to pull all 8 close to that 300k but my fronts run way less so this has been working
    I pull my steers just under 200, maybe 175k just because that’s where everything takes a beating and my only lifeline between the ditch, then I’ll hold those for extra trailer tires if I need but haven’t yet
    I’ve had good luck with off brand tires but I don’t drag my gear through the ditches either so just driving well and watching tire pressures will do much more good than brand alone
  10. Midwest Trucker
    5,871
    21,125
    Aug 31, 2018
    Not sure what you pull but Bridgestone is a good tire. Obviously Michelin as well.
    shooter19802003, Beaver9 and GYPSY65 Thank this.
  11. Beaver9
    966
    1,183
    Jun 15, 2020
    Great Dane Reefer/I pull frozen food.
    Speed_Drums Thanks this.
