I need help again! Trailer won't dump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by parsonsba, Sep 19, 2014.
  1. parsonsba
    parsonsba Bobtail Member
    7
    Sep 9, 2014
    I have never pulled anything other than a dry van, and the company I work for now is just acquiring its own equipment. I just changed the wet line hose on my company's tractor. We cannot get our trailer to dump now. Do I need to bleed the air out of the line first? The PTO is engaging and there was fluid in the line when we changed out the wing nut fitting, but not much. Someone please help, cause we don't know what we're doing!!
  3. 201
    201 Road Train Member
    12,058
    24,619
    Apr 16, 2014
    high plains colorado
    Hi parsonsba, it's really a simple system. Did it dump before you changed the line? I don't think you have to bleed the system. Lines reversed on the pump? Up down control not adjusted right? Some fittings have a one way valve at the connection so if you remove the hose, oil doesn't pour out, is the wing nut fitting pushing that valve down? That's all I can think of.
    parsonsba Thanks this.
  4. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    I don't know anything about this either, but be very careful! I've only seen the quick connect fittings, but the last thing you want to do is have pressure in the lines or air while trying to disconnect the lines. Be safe, wish I could help.
  5. blue94
    blue94 Bobtail Member
    5
    6
    Aug 22, 2014
    I bet I might know what it is... we have dump trailers here and if we don't use the pto pump for awhile on the truck the plunger on the pump can stick.
  6. blue94
    5
    6
    Aug 22, 2014
    Was going to pm you but I don't have enough posts yet.
  7. parsonsba
    7
    Sep 9, 2014
    We got it figured out. One, the fitting was wrong, so the one way valve wasn't opening. Two, I wasn't using the PTO lever correctly. In the end, we got it going and felt like idiots after we figured it out. Next problem is getting a liner for the trailer. Any suggestions on vendors? What about Installing it yourself vs having it done "professionally"?
  8. 201
    12,058
    24,619
    Apr 16, 2014
    All right! I've heard the thin plastic liners work good, shouldn't be that hard to install. Depends what you are hauling. Years ago, before liners, when we would haul big rocks, I'd put down a little sand first to cushion the rocks. Broken concrete or scrap steel did the most damage, don't forget the sides too.
  9. Giggles the Original
    Giggles the Original Road Train Member
    well was gonna tell ya sounds like u had ur fittings reversed..but looks like ya got it
  10. parsonsba
    7
    Sep 9, 2014
    It is a single fitting, but yeah I got it figured out, thanks.
    Giggles the Original Thanks this.
  11. parsonsba
    7
    Sep 9, 2014
    [QUOTE="semi" retired;4253267]All right! I've heard the thin plastic liners work good, shouldn't be that hard to install. Depends what you are hauling. Years ago, before liners, when we would haul big rocks, I'd put down a little sand first to cushion the rocks. Broken concrete or scrap steel did the most damage, don't forget the sides too.[/QUOTE]
    It will basically be trash laden sawdust, but there could potentially be soil and rocks in the future. I'm thinking no less than 1/2 inch but debating 3/8. Just looking for more info and "real world" input since this is a very new field to me, not to mention to the company I'm with!
