I need a tarp storage rack!
Discussion in 'Flatbed Trucking Forum' started by Bad Monkey, Mar 2, 2017.
  1. Bad Monkey
    Bad Monkey Medium Load Member
    576
    367
    Jul 18, 2012
    Goshen, IN
    Hey everybody, I need ideas for a tarp storage rack on my trailer. Right now i have to squeeze them on to my headache rack and it doesn't always work so well. The problem with my east trailer is I am not supposed to drill in to the frame, at least that's what the sticker says. Are there any other options? Thanks, Rob. NCM_0098.JPG NCM_0100.JPG
  3. spyder7723
    spyder7723 Road Train Member
    15,468
    25,079
    Mar 31, 2013
    sarasota, fl
    How do you think east mounts the toolboxes? They drill holes in the frame. If you are worried about warranty concerns, have an east dealer install a box.
    Crusader66 and Lepton1 Thank this.
  4. frt60
    frt60 Medium Load Member
    312
    266
    May 22, 2014
    They maje a tarp tray for the top of chain rack about 250 dollars
  5. spyder7723
    15,468
    25,079
    Mar 31, 2013
    sarasota, fl
    If you don't want to spend the money on a box, cut a piece of 3/4 inch plywood that fits across the frame rails. But it's a pain to climb under the trailer every time you need to grab your tarps.
  6. Bad Monkey
    576
    367
    Jul 18, 2012
    Goshen, IN
    That may have to do for now. I don't have to store them all this way very often.
  7. Bad Monkey
    576
    367
    Jul 18, 2012
    Goshen, IN
    Yeah, but then I would need to mount a crane to lift them up. LOL. The 2 big ones are 100lbs each, and I know I am not man enough to heave them up there.
  8. Bad Monkey
    576
    367
    Jul 18, 2012
    Goshen, IN
    Well the trailer was made i 1997 so I think the warranty has expired. Maybe i will just do that.
  9. spyder7723
    15,468
    25,079
    Mar 31, 2013
    sarasota, fl
    I just keep mine on the deck. If i load something that required the entire deck i get the fork lift pair to stick them up on the freight. Only on insulation loads is that not possible.
  10. spyder7723
    15,468
    25,079
    Mar 31, 2013
    sarasota, fl
    If you are really worried about drilling the frame, build a rack and mount it to the crossmembers.
    kylefitzy Thanks this.
  11. Razororange
    Razororange Road Train Member
    2,859
    27,162
    Dec 20, 2011
    Milwaukee, WI
    You should be fine with drilling the frame. Just don't drill through the top or bottom flanges. If you wanted you could contact the manufacturer and see if they have any guidelines regarding size and placement of the holes. They will have specs for how large and how close together the holes can be before you start compromising the structure of the frame.
