i have an 3406a pc its low hp lookin to juice it up a little maby 440hp
Discussion in 'Trucks [ Eighteen Wheelers ]' started by clint1234, Oct 2, 2014.
  1. clint1234
    clint1234 Bobtail Member
    im looking to make some more hp outta this motor , 3406a pc vin number on motor is 92u4148 . right now it has 300hp looking to push maybe 400 425 looking to see if any one knows what pistions numbers or turbo i need to use to get her where i need it ,i have an after cooler for it just stuck on turbo and pistions ...... any ideas!!!!!?
    thanks,
    clint
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Might ask Pittsburgh Power. They can make a 300 run like a scalded cat.
  4. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    not much you can do to an a-model. except pistons, turbo, fuel nozzles, and maybe cam. also convert to a cac instead of water cooled air. aint cheap to do. unless you have a donor truck sitting around. one good thing about an a-model they seam to run forever. these modd's are allowed to do and talk about.
  6. Longhood379
    389
    125
    Nov 30, 2009
    Cremona AB
    A precup 3406 only has one piston pack , the cam is what the cam is, you can back the fuel rack limiter screws out, and maybe gain some there if your nozzles are big enough. I doubt going air to air would be much benefit. anything other than adjustments is pretty pricey, and it would be a lot more practicle to swap to a 7FB 3406 if you want to make more power. A more modern turbo might help, like a gated one from a 3406E 475
  7. wore out
    wore out Numbered Classic
    15,319
    184,946
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Well I start with doing away with the precup head, put DI head on it. Opens up the possibilities on the piston packs available. Throwing a stock turbo on one off of something else is a crap shoot without looking at lots of variables. Not saying it won't work but look at several things first I personally think a non gated OR-6051 would do a better job on a A model. There are some governor mods that really help too. Like Superhauler said a cam. Hillcrest cam in Little Rock can be of assistance there. Air to Air would be a help. Or you could go all out and go compounds like I run on my B or C depending on if you look at block serial number or pump part number. Course what ever you do an ol A model is gonna drink the fuel.
  8. FLCGuy
    FLCGuy Bobtail Member
    I put a turbo from a late b early C on my 400hp a in my 1986 FLC...and I can duplicate 5.8 miles per gallon @ 86000 pounds anywhere in the Pacific Northwest
  9. AModelCat
    154,214
    What do you see for boost out of that? How easy of a swap was it? Any difference noticed in performance? I've been looking at doing that to my A block kitty when it comes out of the truck this winter for an overhaul.
