I have a Question about the ISX VGT turbo.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by boxcarmonument, Sep 22, 2011.
  1. boxcarmonument
    boxcarmonument Light Load Member
    70
    42
    Sep 22, 2011
    Canton Ohio
    :biggrin_25510:I recently bought an 08" Pete 389. With a ISX @ 550HP I got the insite report from Cummins when I bought the truck. The truck had a new turbo put in On 5/9/11 and another one on 6/2/11. I bought the truck August 2nd. And Last Saturday the turbo failed again. This time it cost me. The truck didn't have any turbo failures until 272,000 miles. Now in the last 30,000 3 turbos.
    What is the variable here? That the origional turbo would last 272,000 and than go through 3 in 30,000. I would speculate that the DPF needs cleaned but it's not full enough for the truck to have the clean dpf screen light up. What is the problem with these turbos that they have such a high failure rate? And it's not the impeller that's failing it's the VGT seizing on it.
    Also I was getting close to 7 MPG with the old turbo. And now with this new one I couldn't get 5 MPG. So I wonder if the turbo that was on the truck when I purchased it, was bad from the get go. But in a good way LOL.
    Is their anything that can be done to prolong the life of these turbos? I just bought one and still have warranty on the motor and new turbo. Till next year. But as soon as that expires it looks like it's going to PDI. If I can't get this problem straightened out.
    I should also state that this is my first cummins having owned mostly Cat's till now. But didn't buy a newer truck with a Cat because I had heard that they were having so many problems with the DPF systems on them.
  3. Dutch
    Dutch Light Load Member
    194
    58
    Commiefornia
    What do you mean by the turbo going out? If the selector shaft is frozen/not reaching the full travel. There is a cleaning procedure to perform on the sliding mechanism, if damage is found then turbo replacement is necessary. EGR coolers leaking will cause the selector shaft to stick/blind. Also is the calibration at the latest software?
  4. boxcarmonument
    70
    42
    Sep 22, 2011
    Canton Ohio
    Selector shaft was frozen. With the turbo actuator off you couldn't move it. Cummins said it needed a new turbo. Without removing the turbo if you get what I'm saying. What is the cleaning procedure? Also how would I know if the EGR cooler is leaking?
    I cannot say for certain that it's the latest software. I guess I would need to go back to cummins. Would the software automatically update when they plugged the motor into INSITE? The truck was plugged in to pull the check engine code I had gotten. The code was for a Turbo Actuator. When I called Cummins he said that could be a 100 things. And wanted to know the actual code.
  5. Dutch
    194
    58
    Commiefornia
    Oh, Ya the turbo has to be removed to do the cleaning, the turbine housing off and the actuator. Then do a few checks to see if its cleanable or needs to be replaced. If the egr cooler is leaking you would be using coolant.
    If you have the insite report and in the feature and parameters section it will give you like something like this AV10064.34 thats the calibration. No they have to load it into the ecm.
  6. boxcarmonument
    70
    42
    Sep 22, 2011
    Canton Ohio
    Not losing coolant. Nothing on insite report But I only have the repair history. I guess I will go to cummins and see about the parameters. When I get Home next week.
    Does Cummins do the cleaning? Or do they just R&R the Turbo? And they deducted that I needed a turbo without removing it like I had said earlier. The Turbo was functioning I actually drove it to the dealer. I had a Check Engine light the day before and called and got an appt. Than the next day The code had cleared itself. No faults found is what the computer told me. I had this done at Cummins Cal Pacific by the way.
  7. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    No, turbos shouldn't fail like that. Exhaust back pressure sensor may be plugging up aswell causing the turbo to work when it doesn't need to and getting carboned up.
  8. boxcarmonument
    70
    42
    Sep 22, 2011
    Canton Ohio
    You may be right there. I didn't pay too much attention coming across AZ, NM and TX. But from louisiana to Florida. It took 20 PSI just to drive down the road with the cruise on. Granted I have a flat top truck and the peice on the top deck of my trailer had me at 13" 6" and I had about a 5 foot gap in the middle of the trailer between tarps. So those variables may have came into play. But now that I'm empty it's still taking 10-12 PSI just to drive down the road. This is with the new turbo by the way. So I am wondering what they didn't catch at the shop.
    As far as the Exhaust back pressure sensor can it be removed and cleaned? Or does it need an R&R? Also where is it located. If it can be cleaned.
  9. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Located right side above thermostat housing. Will have a 3 wire connector plug on it. Yes, just blow it out. Look into the hole it threads into and check for carbon build up there too.
  10. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    Truck dealers and turbo shops are not allowed to do any servicing to to those turbos. That's why they always change a new one even if they are not actually broken, just dirty. Holset doesn't sell any parts for those turbos but there are some companies making aftermarket parts for them. Next time when you "blow" a VGT turbo, don't give it to the dealer but send it to some independent turbo shop to be serviced.
  11. vangtransport
    vangtransport Heavy Load Member
    863
    2,837
    Apr 14, 2009
    Cummins and Volvo both use the same "Holset" (cummins) turbo. If you are spooling higher than normal when light try checking the EGR system also.
