I got pull over today in Michigan for frost law
Discussion in 'Trucking Industry Regulations' started by orangepicker, Mar 19, 2014.
  1. orangepicker
    orangepicker Road Train Member
    1,159
    679
    Nov 9, 2011
    florida
    Along with singing birds and blooming flowers, every spring in Michigan brings heaving and buckling pavement. Many local jurisdictions in Southern and Mid-Michigan have already implemented "frost law" or reduced loading provisions to protect their roads. These restrictions drop the legal axle weights of vehicles by either 25% or 35% depending upon the road construction and design. While Michigan's weight laws apply to all vehicles, reduced loading has the biggest impact on commercial operations, due to the size and weight of the vehicles that are used.
    State law provides the months of March, April and May are automatically reduced loading months, but the statute also allows the Michigan Department of Transportation (MDOT) and the county road commission to implement those restrictions earlier or suspend reduced loading, depending upon weather conditions.
    Along with reduced loading provisions are reduced speeds. For vehicles over 10,000 lbs. operated on reduced loading roads, the speed limit drops to a maximum of 35 mph, regardless of the posted limit. Speed, in conjunction with axle weights, has a tremendous impact on the creation of potholes.
    The term "frost law" refers to the amount of frost remaining in the ground. The warming and cooling of the ground during the up and down weather of spring causes the pavement to heave and buckle, creating potholes and broken pavement.
    MDOT has a 24-hour phone number where callers can listen to a recorded message on the current status of reduced loading provisions on state roads by calling 800-787-8960, or by going on-line at www.michigan.gov/mdot. For local roads, contact your county road commission, or go on-line athttp://www.micountyroads.org.
  3. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,962
    9,546
    Oct 18, 2010
    NW Indiana
    Maine, Wisconsin and Minnesota have similar laws, and maybe other states. Enforcement varies but worthwhile to pay attention.
  4. snowblind
    snowblind Heavy Load Member
    775
    636
    Jan 29, 2011
    conover nc
    they had it on the big signs around mi
  5. BNR32
    BNR32 Heavy Load Member
    729
    265
    Aug 20, 2010
    denver, CO
    I was trained on all this nonsense but never saw any of these signs. but my driving in those states was fairly limited. its bs though. I remember hearing at our Michigan terminal there was only one possible route and the cops would just sit and wait to bust trucks if they took the wrong road. messed up.
  6. orangepicker
    1,159
    679
    Nov 9, 2011
    florida
    i pull out of the ford plant in Wayne, mi then turn onto a local street to get on I-275 the street was like a 1/4 mile long. as soon as i turn off that street he came out of no where with the blue lights going. i pull over in a turning lane he whips in front of me like i just rob a bank. get out and starts screaming about the frost law. then lic med card and bol. when he seen i only had 29,000 on he cool off a little but still inform me this could be a $3000.00 fine. said he will let me go this time...lol after looking up the law i see why he let me go. i was way under the 25 to 35 percent weight. oh and there wasn't any signs at all on the street about weight limit not even a no truck sign....so watch out if your load is over 35,000....
    OPUS 7 Thanks this.
  7. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Tell them they need to dig down at least 42" and build a really thick road, lol. It seems like they could come up with a better warning system. I've been to MI many times and never knew anything of frost laws so it's a good heads up for others. I guess I've been lucky but I've never have been but a few blocks off the interstate in the winter.
    States are different on their road construction and it sounds like MI is a cheapy. You can go to other northern states and they don't have issues.
    towtrucker Thanks this.
  8. FwL
    FwL Medium Load Member
    438
    331
    Aug 30, 2011
    Sandpoint, ID
    Idaho, BC and Alberta have breakup limits posted right now as well.
  9. Ridgeline
    22,103
    113,210
    Just an FYI ... the roads here are a problem for a couple reasons
    1 - this year when we had the snow and the zero degree days and minus zero nights, they didn't use salt but plowed the roads. There was no water that was getting into the slabs and then cracking the cement because it was too cold to begin with. However some of the seams popping up because of a lack of proper foundation, shifting because they were giving way long before the snow came so the plows would catch a lot of the slab seams and tear them up. example is Mound road where they did some repair work last year and before the snow was pretty good but a couple days after the snow in this bitter cold weather it was like an artillery barrage was unleashed on the road.
    2 - this state has poor specs for the roads to begin with. There was always money for rebuilding roads and they used the idea "we will just fix it next year" form of planning but because they gotten cheap in the past 15 years and changed how the roads are put in, they just don't last more than a year here and this isn't because of winter - it happens all year round. It has nothing to do with the frost but the general maintenance (sealing seams) to prevent washout of the foundation in some spots and/or having proper foundation to begin with. One road you can see this is I75 from the Ohio border to mm25, there are some areas after being rebuilt that just sunk and others where the slabs shifted and cracked then became a mess.
  10. SlowPoke44magnum
    SlowPoke44magnum Medium Load Member
    407
    519
    May 3, 2009
    Walbridge,Ohio
    Going up and down I-75 they have the light up signs proclaiming frost laws are now in effect. Of course they don't say which roads, the weight limits, etc. but it is posted ;)
    That stretch from the Ohio line to at least the 25 is just about the worst stretch of road I've been on in years, I was running containers to CP Rail off of Southfield at least 2-4 times a week two or three times a day. My back is still trying to recover from it. You know the road is bad when you go over one of those craters and your chassis with an empty container on it jumps a foot or two to the left or right when it crosses the crater ;)
  11. mjfmjf
    mjfmjf Light Load Member
    71
    13
    Jan 23, 2012
    Harpersfield, Oh
    Amen SlowPoke...I hate that stretch as well. Forces one to run in the middle lane as the right lane is unbearable.
